Changing the Transponder (FOB) Battery - Pictorial
The dreaded transponder low battery warning
Buy replacement battery - CR2025
Required Tools - Nothing fancy - I just used the flat blade screw driver from my pocket tool
Transponder (FOB)
Slot to open transponder (FOB) located at one end
Flat blade screw driver in slot and twist to open - Ensure screw driver fits and is not to small
Transponder (FOB) opened
Transponder (FOB) with old battery
Removing the old battery - use a flat screw driver with a small blade for this task
Battery removed
New battery fitted - Old battery along side
Transponder (FOB) back together
Test functionality on GTR
All done - 12 minutes which included going into the garage twice for photos,
Pulling the FOB apart, taking photos step by step, getting the photos off the camera and
uploading them, then writing this pictorial.
Not hard and does not take long.
Please login or register.
Login with username, password and session length
