Author Topic: $6.16 cat ring  (Read 1093 times)
Offline dimetraveler
  • COG#: 11100
$6.16 cat ring
« on: July 24, 2013, 05:46:12 pm »
Well put on the much talked about Cat ring,it works well but the trade off is a stiff throttle,which in turn sort of defeats why I put it on.this would be great for slabbing cuts down on hand fatigue.
WOW
Offline runnerb0y
  • If you don't think too good, don't think too much.
  • COG#: 10517
Re: $6.16 cat ring
« Reply #1 on: July 24, 2013, 05:52:36 pm »
I just added the Go Cruise and it works GREAT!
Did I mention that it works great?  It really does.  The best 13.99 I've spent for any farkel.
| COG#: 10517  |  2012 C14 - Candy Arabian Red  |
Offline Easy13
  • '05 ZG1000 Concours "Harlow's Revenge"
  • COG#: 11001
Re: $6.16 cat ring
« Reply #2 on: July 24, 2013, 05:59:32 pm »
Airhead Beemers had a throttle friction screw on the housing.  After 15+ years of having a throttle that stays where it's put, I'm used to it.  Now all my bikes have the O ring mod.
Cognito Ergo Wrenchum
Offline Bob_C_CT
Re: $6.16 cat ring
« Reply #3 on: July 24, 2013, 06:36:43 pm »
I roll it completely on the throttle when not in use, in town riding etc. Then roll it back between weight and throttle when I know I'll be slabbing it.
Offline SmokinRZ
  • COG#: 9430
Re: $6.16 cat ring
« Reply #4 on: July 31, 2013, 03:14:09 pm »
I have used vista cruise and throttlmeister on other bikes, but the Cat O ring is so easy I just keep using it on the Connie.  Yes, you have to roll it off when you get off the interstate.  I have Murph's potato smasher bar ends so there is no risk of it rolling off on the ground.
Offline Movinfr8
Re: $6.16 cat ring
« Reply #5 on: August 09, 2013, 11:58:37 pm »
I second the go cruise. But I splurged and got the aluminum adjustable one $35. Works great.
