Hey guys, I did not have time to take a lot of pictures, but the install was straight forward. I made a pig tail or wires to allow easy removal then unplug if needed.
Using the 2 hot wires from the factory (yellow & black is negative, if you wondered), I got this installed.
I wanted it there so I could lock my phone in to charge if needed. Since these leads are not switched, I did not want access to the open while I was away from the bike.
I love these plugs from Amazon. Easy install, good tight nuts to hold in place, and easy install.
