Author Topic: 1987 concours air bleed screw  (Read 993 times)
Offline wayne_martin_TN
« on: June 02, 2009, 11:22:00 am »
Just bought 1987 concours and want to change cooling fluide.Can anone tell me where the air bleeder srew is located. Right side near foot break or left side near foot shifter. Tks Wayne
Offline Colin
  • I'd rather be riding!
    • Facebook
« Reply #1 on: June 02, 2009, 12:16:00 pm »
On the C10 there are 2 air bleeds.  First is on the side of the Thermostat RHS of bike above the carbs.  The second is on the Water Pump. LHS above foot peg.    The drain screw is under the LHS of the bike on the tube that connects the water pump to the radiator, you will need to remove the belly pan.    If I recall correctly there are pictures in our technical section.    All need a 10mm socket.    Colin Prior  COG Webmaster    Lake Forest Park WA  COG#7767  AMA#1081764  ROK#20000617
Colin Prior
Offline 2linby
  • I rode today, did you?
  • COG#: 5539
« Reply #2 on: June 02, 2009, 09:34:00 pm »
Just what Colin said. However never open up the lower bleeder with the engine running. You can cause a condition called cavitation. And that is not good for the pump! (a gross understatement! :8o: )  AKA "2linby" That's 2-lin-by folks!  Northwest Area Director  COG #5539  AMA #927779  IBA #15034  TEAM OREGON MC Instructor    http://community.webshots.com/user/2linby  http://tinyurl.com/njas8 (IBA BunBurner Gold Trip)  http://tinyurl.com/lwelx (Alaska trip)
« Reply #3 on: June 03, 2009, 03:03:00 pm »
Thanks much for the information I will work on it this weekend,This was a big help tks Wayne Tn
« Reply #4 on: June 03, 2009, 03:04:00 pm »
Thanks for the responce I will be working on it this weekend, thanks again for the information, Wayne Tn
