Author Topic: 7TH GEAR  (Read 2425 times)
Offline Jerry
  • COG#: 11147
7TH GEAR
« on: September 08, 2014, 01:53:06 pm »
While reading posts, i come across this term of SISF 7th gear, it's probably explained somewhere. Could someone please enlighten me, thank you.
On hand, 1966 triumph tiger,1969 triumph trophy,1975 yamaha dt 400, 1977 yamaha IT 175, 1979 suzuki TS 100, 2009 C-14, 2010  H.D. XR1200
Offline Victor Salisbury
  • COG#: 3673
Re: 7TH GEAR
« Reply #1 on: September 08, 2014, 02:06:00 pm »
The 7th gear unit is a re - geared bevel drive unit for the C10.  Steve called it the "7th gear unit " because with this unit you don't want to upshift to another gear when you're already in 6th anymore.
From Steve's information:
The 7th gear unit has 12% higher gearing than a stock Concours bevel drive. This means you will run with 12% less rpm per gear per road speed. For instance in 6th gear, rather than 5000rpm = 80mph, you will now only turn 4400 rpm for 80mph. Your exact rpm may vary somewhat due to your choice of tire and size of tire.
highly recommended
Available through : https://sites.google.com/site/shoodabenengineering/
HTH
Vic Salisbury
COG #3673
'97 Connie "The Grinch"
Sarasota, FL
www.cog-online.org
Re: 7TH GEAR
« Reply #2 on: September 08, 2014, 02:12:34 pm »
7th gear  is a bevel gear with a higher tooth count. Just like a 1 tooth bigger front sprocket, it lowers RPM which gives the C10 a more relaxed cruising speed on the High Way.
Offline diablo6v
Re: 7TH GEAR
« Reply #3 on: September 08, 2014, 02:47:29 pm »
I have enjoyed mine for over 50,000 miles now... :)
Re: 7TH GEAR
« Reply #4 on: September 08, 2014, 04:37:52 pm »
ameteur ... the guy who has my very first one posted up last year that he had over 150k on the unit and it was still going strong...on an 05 with over 200K ! Steve
Offline DC Concours
  • 2001 Concours, ~19K miles
Re: 7TH GEAR
« Reply #5 on: September 08, 2014, 09:56:31 pm »
Hey Steve...after you installed your new jets the added power makes me shift through the gears quite fast. Is that normal and will the "7th gear" mod calm my left ankle?
How difficult is this for a novice such as myself to install?
Re: 7TH GEAR
« Reply #6 on: September 08, 2014, 10:48:32 pm »
yes, you'll shift less, everyone remarks that 1st gear becomes actually useable. The 7th gear unit really shines when running long hauls to the twisties.
 While I can't say what an individuals mechanical abilites are without knowing some about them, the 7th gear unit is a plug and play unit that only requires removing the old bevel and bolting the 7th gear unit on. Basic and tools and a day's work. Steve
Offline Jim Snyder
  • COG#: 7055
Re: 7TH GEAR
« Reply #7 on: September 09, 2014, 06:35:33 am »
Yes highly recommended indeed. Really makes a difference with the "buzz" by reducing the RPM's at cruising speed. I am the proud owner of one of the first units also and it is smooth as glass.
Offline RWulf
  • COG#: 7122
Re: 7TH GEAR
« Reply #8 on: September 09, 2014, 01:53:21 pm »
You will think you have a differant bike or got on someone bike , not yours..
Offline Nosmo
Re: 7TH GEAR
« Reply #9 on: September 12, 2014, 01:19:48 am »
This is the single best mod and the best money you will ever spend for your C-10.  I have it along with Steve's cam reset gears and 2 minute mods, for more torque down low.  I find myself shifting less. I can put the bike in 4th gear and go around the backroads all day long, whatever speed I want.  Highway cruising is much less busy, quieter, more relaxed, etc.
2003 Connie    2007 Wee-Strom
Re: 7TH GEAR
« Reply #10 on: September 12, 2014, 01:49:05 am »
ummmm, can you please send me all the other gear combos you removed, I'm currently set on the 5th gear mod..... yes, pulling stuff apart.... you told me I didnt need to worry...... wanna go drag racing , shortly. :)) :)) :)) :rotflmao: :beerchug: :beerchug: :beerchug:
