Author Topic: A question regarding GenMar Bar risers  (Read 1550 times)
Offline delling3
  • 2nd Time Around
  • COG#: 11850
« on: September 09, 2015, 04:06:45 pm »
I went to adjust the spring preload on the forks of my C-10 this morning.  Since there are bar risers installed, I proceeded to remove the handle bars to gain access to the adjusters.  I was somewhat surprised to find no set-screws installed on the left side fork.  Both were in place on the right.  I assume that when the risers were installed the the PO simply forgot to install them.  Hard to believe that the left side both vibrated out.
So this got me to thinking.  What exactly is the role of the set screw.  It doesn't seem to add anything to the installation.  What am I missing?  Now I am off to the hardware to see if I can get some set screws (not too optomisitic).  If I can't locate replacment, can I just use one on each side?  I am leaving on a 4-day trip tomorrow . . .
Chris Delling
2006 Concours, risers, knee savers, throttlemeister, Murph's grips,  23" Clearview, KB fork brace, SISF's carbs, 2MM, and advanced exhaust cam gear, 7th gear, Spoofak.  Waiting in the wings:   McCruise Cruise Control.
Only dead fish go with the flow . . .
Offline Solomookie
  • COG#: 11738
Re: A question regarding GenMar Bar risers
« Reply #1 on: September 09, 2015, 05:33:59 pm »
Chris,
I've had GenMar risers for years, and about the only purpose I can think of for the set screws is to keep the riser square on the mount as you're bolting the handlebar down.  Once the bolts are in, the set screws seem completely superfluous.  And yes; I do believe they can vibrate out because I only have one on the one side and I know I started with two each.  I'd move one of the rights over to the left just for appearance sake, but then I'm the type that can't walk past a crooked picture on the wall without straightening it.
'98 Connie x 2, farkle expenditures nearing the GNP of Bolivia; it's a sickness.
« Reply #2 on: September 09, 2015, 06:02:41 pm »
the original intent of the setscrews was to hold the short "insert" tube in place, this is the one that sits on top of the fork tube, and allows using the original fork cap cover..
http://www.genmarmfg.com/kawasakis.html
I caution about tightening a cup point set screw on the fork tube, as it will create a divot on the fork tube, and you will have difficulty removing the tripple tree, or the fork tube itself, at a later date. You will end up having to file down that displaced metal caused by the cup point of the setscrew digging into the fork tube.
Offline delling3
  • 2nd Time Around
  • COG#: 11850
« Reply #3 on: September 09, 2015, 06:18:27 pm »
Thanks Guys -
I was happily surprised to find the needed missing set screws at my hardware.  Seems like they have a pretty limited selection of metric stuff, and I have been disappointed more often than not.
I reinstalled the setscrews with some blue loctite.  Should prevent them from vibrating out in the future.  I still am not certain that they are needed, but since I could find them I put them in.
Chris Delling
Offline Outback Jon
  • COG#: 9506
« Reply #4 on: September 09, 2015, 06:45:34 pm »
I haven't even looked at mine in a while, but last time I did, some (I don't even remember how many) had vibrated out.  Haven't bothered replacing them, and with 67k on the bike, almost all of it with the risers installed, (and probably missing the set screws) I'm not going to worry about them.
