Author Topic: Accessory plug install  (Read 1019 times)
Offline V8shadow
« on: June 06, 2013, 10:12:46 pm »
  Can't I do this by simply hooking up a radio shack cigarette plug (female end) right to the battery with an inline fuse?  It would only be used to charge a quick charge led flashlight (90 sec charge time) or to charge a cell phone or ipod.  What amp fuse should I use?  I kinda feel like a hack asking this but I am not seeing why this should be so complicated.
Ken
1986 Connie, "Broken Pony"
"Ignorance of the consequences should never be mistaken for bravery"
Offline fred-houston
  • COG Membership Officer
  • COG#: 9066
Re: Accessory plug install
« Reply #1 on: June 07, 2013, 08:28:06 am »
Any route you take is really not that complicated, there are just a bunch of options. Sure you can do it the way you described above.  If all you plan on doing is charging a flash light or some electronics, then all you would need is a low amp fuse.  I usually use a 5 amp fuse, but you can go smaller than that.
Missouri City, TeXaS
1999 C-10 EFI (Semi Naked)
2016 Yamaha Super Tenere
Offline Mr Orange
  • COG#: 6601
« Reply #2 on: June 07, 2013, 09:28:17 am »
I would highly recommend using accessory plug that Murph sells on his site.  :great:
Offline cra-z1000
  • Keeping it upright..
  • COG#: 9790
« Reply #3 on: June 07, 2013, 11:41:34 am »
I used a marine outlet from Wallmart .
1987 C 10
80 Kawasaki KZ 1000 MK 2
74 Honda 750 four ss
73 Suzuki 550 triple
72 Honda 550 four
Offline V8shadow
« Reply #4 on: June 07, 2013, 02:53:17 pm »
Ok thanks guys.  I saw something decent on autozone.  Going to check them out now.  No time to order online.
Ken
