Author Topic: Admore light install  (Read 712 times)
Offline MrSkydriver
  • When all else fails, read the instructions!
  • Gregg Hackett
  • COG#: 10363
« on: September 02, 2012, 05:47:26 pm »
I have a question regarding the Admore light install.  In the picture they provide, they say to drill the hole in the Givi trunk facing the front of the bike.  Wouldn't it be better to drill the hole on the bottom of the case?  Can anyone help me?   ::)
Gregg
(707) 321-4909
Gregg Hackett
'08 Concours C14 ABS
Boerne, TX
COG #10363
Growing old is mandatory...Growing up is optional
Offline bldoink
  • COG#: 9409
Re: Admore light install
« Reply #1 on: September 02, 2012, 10:30:15 pm »
I installed some of their stuff on my wife's versys. The detachable connectors seem pretty water tight as well as the through hull parts that penetrate the box. I would still desire to put the hole out of direct exposure to the weather. However, the primary concern would be convenient placement for the wiring. If that necessitated putting it facing the front, then that's where I would put it. You don't want dangling wires, even when the box is off.
Offline Piston720
  • COG#: 10213
« Reply #2 on: September 04, 2012, 12:34:52 pm »
I have had the led Run/Signal unit installed for about a year now.
I mounted the connector as suggested and have been through days of heavy rain without a problem.
The location at the front (bike front) and left side (when riding) works real well for wiring purposes as well.
I mounted mine just above the passenger grab rail and close to the back of the seat to keep it out of the way.
