Author Topic: The Ole Cutting Board Rack Mount  (Read 877 times)
Offline Alekkas
  • COG#: 10513
« on: September 06, 2014, 12:03:02 am »
I may have moved on to a 919, but I am still a C10 type cheap SOB!
So, I got a Kappa 35L top box (givi knock off) for $59!  Givi and Kappa call for a $60 rack to be attached.  I have read several times here about using a walmart or whatever cutting board.
Here are the rails installed from givi.  Great fit BTW...
Do I simply attach the cutting board with four bolts and then drill holes for this unversal type rack that came with the top case?
Does that seem right?  BTW, so there is not confusion, this universal rack came with the top case and fits IT perfectly.
Thanks for any info.
Seagiant needs to post more!
'08 C14 / PGR  / IBA
Some ride reports:
On two wheels:
