Author Topic: Audiovox Cruise Control Problem  (Read 5724 times)
Offline rabbott5
  • COG#: 7746
Re: Audiovox Cruise Control Problem
« Reply #25 on: October 02, 2014, 04:20:49 pm »
One other suggestion here is to go in and work the switches on the dip switch that sets operating conditions (7 switches). Just click them back and forth a couple of times ending up in the same setting as before. If the contacts in those switches get dirty or corroded they could be confusing the servo.
Dan
Thanks Dan! I'll give that a try.
Offline RWulf
  • COG#: 7122
« Reply #26 on: October 03, 2014, 01:18:05 pm »
So how do you get to those valves in the servo?
Offline Zorlac
  • COG#: 6962
« Reply #27 on: October 04, 2014, 02:49:16 am »
"how do you get to those valves in the servo?"
The back half of the servo needs to come off to see them iirc.
COG #6962
Offline rabbott5
  • COG#: 7746
« Reply #28 on: October 12, 2014, 01:36:27 am »
Well, I'm back up and cruising.  It would seem the servo went bad.  I replaced it with one from Murph. THANKS!  When I get back from my trip, I plan on doing surgery on the old servo to see what went wrong.  Just happy the unit is working and I'll be able to use it on a few of the long sections heading to Arkansas and back.
Offline SteveJ.
  • COG#: 5603
« Reply #29 on: October 12, 2014, 11:49:10 am »
Glad you are hooked up. It will be interesting to find out what the issue is.
Tick Tock, baby (Ironbuttal)
