Author Topic: Avon Tyres - Did I set a record?  (Read 1831 times)
Offline Greg Habel
  • COG#: 7010
« on: August 18, 2009, 07:28:00 pm »
With all the talk about how few miles the Avon Storm and Azaro get, I was pleasantly surprised I have almost 11,000 on them.  I rigorously check tire pressure (40 front, 42 rear) and weigh about 160 lbs.   A mix of twisties and slab but I prefer twisties.  At about 9,000 I started developing cupping on the rear but have held out in changing.  The cupping is significant now and time for a change.  The front has cupping but minor.  Who says these Avons can't last long?!  Greg H from Mass, Connie Droppers Anonymous Awards Dude  COG# 7010,a Tracey  CDA 120 (2.0)  99 Connie "Herrin Christabelle", 05 Ninja 250
« Reply #1 on: August 18, 2009, 08:15:00 pm »
I use to get about 7,000 out of the Azaro rear. I'm fairly hard on tires too!    Bionic Bob  COG & AMA member  First C14 CDA member #0220  2008 C14 & 2003 Mean Streak
Offline Wizeguy
  • Closet Hooligan
  • COG#: 12487
« Reply #2 on: August 19, 2009, 10:32:00 am »
 I no longer have my Connie, so I don't know if my 2nd set reached/will reach the same mileage.  But my first rear Azaro was replaced @ (IIRC) approx 12,300 mi.  So it can be done!
Mike B / Seatac, Washington
1989 C10 "Gigi"
Former COG#6624
Offline Paulie
  • COG#: 4561
« Reply #3 on: August 19, 2009, 03:41:00 pm »
Then don't git them Wang tars...cuz you'll never wear em out.    Diff strokes/ridin style fer shure. IIRC I got ~6k outta my Avon rears, not enuf.  01 Conc, Mijami Floriduh  OTP 06: http://tinyurl.com/2vk9o2 route map: http://tinyurl.com/4p7pmd
Offline Charlie_Gary_AAD
  • COG#: 8048
« Reply #4 on: August 20, 2009, 12:03:00 am »
I think this begs the question "How hard do you brake, and how much is with the rear wheel?(don't forget engine braking)".  I don't brake hard, and my tires last over 10,000, too.  I mentioned this once before, and one of the responders who didn't get very many miles fessed up to really enjoying braking to the max.  So, how hard do folks brake, and what kind of mileage are they getting?  If we were college kids we could build a project out of this for some class. ;)
« Last Edit: August 20, 2009, 12:04:00 am by Charlie_Gary_WA »
Later,
Charlie - NWAAD
COG# 8048
AMA# 603377
Re-defining the phrase "Rides like a grandpa"
Offline Slybones
  • COG#: 6953
« Reply #5 on: August 20, 2009, 12:45:00 am »
I have also heard braking while turning/leaned over is how cupping happens. Brake straight up and cupping goes way down. So I have heard.  2003 Concours, 54K  COG #6953  IBA 28004  http://home.comcast.net/~slybones/Concours/connieMain.htm
2003 Concours, 121K
2005 GL1800ABS, 52K
COG #6953, IBA 28004
Offline DeansZG
« Reply #6 on: August 20, 2009, 06:44:00 pm »
I routinely get 13-14k outta my rear Avon Azaro. The last front Azaro I ran knocked off 16k before it was swapped out for a new Avon Storm. Even at that 16k, it was just barely at the wear bars...
Offline rneal55555_NH
  • COG#: 7889
« Reply #7 on: August 22, 2009, 12:18:00 am »
I wish I kept better records but I thinking I got about 13 or 14 thousand a Storm on the front. Went through 2 Azaro's on the rear in that time but the first was replaced when it was about half worn out when I picked up a nail so I'm thinking I got about 8 or 9 thousand outa the second rear.  Russ Neal  North Stonington, Ct  Originally from Willsboro, NY  04 Connie  99 Yamaha Venture  IBA # 32003  Venturers.org # 1774
Russ Neal  Milton, NH  Originally from Willsboro, NY  04 Connie  99 Yamaha Venture  IBA # 32003  Venturers.org # 1774
Offline captconcours
  • COG#: 6513
« Reply #8 on: August 30, 2009, 12:26:00 pm »
Thought I would chime in, most of my riding is commuting with 85% slab and I am 5'9 170lbs.  I have consistantly on two Azero rears gotten 16,000. I changed the front at the same time out of habit, but this last time I didn't.  I have 8,000 on current rear and 21,000 on the front.  I am not very aggressive while commuting.  ;)  John Ashton  Ft. Worth, TX  COG 6513  AMA 1078826  05 Concours
John Ashton  Ft. Worth, TX  COG 6513  CDA0326  AMA 1078826  05 Concours
