Author Topic: cutting board  (Read 3611 times)
Offline oldsawfiler
  • COG#: 8062
cutting board
« on: September 03, 2008, 03:59:00 pm »
Monday afternoon I went to put some purchases in My JCW trunk and found that it was only hanging by two bolts.  My cutting board mount had broken just aft of the back bolts that atached it to the stock bracket on the connie.  I had mounted the trunk directly by drilling 4 holes in it and the cutting board and using bolts.  The front two bolts were still holding the trunk and the back two were holding the cutting board together.  Any suggestions on how to improve this mounting system?    1990 Aint she a pretty Tomato (the bike ofcourse)  wedshots albums   http://community.webshots.com/user/sawfiler64/albums/most-recent
Offline Brett0769
cutting board
« Reply #1 on: September 03, 2008, 04:56:00 pm »
I saw a double board system that someone had posted where they made the mount for the trunk on one board, the mount to replace the luggage rack out of the second, then bolted the two together. Also, the Givi mount will work if you want to spring for it. I've actually been thinking about this a lot lately, I'd like to replace the current mount though I have to admit, it's gone through a LOT and is still in good shape for me. Wonder what happened that caused yours to break? I've even closed the garage door on my trunk a couple of times and I can still move the whole bike side to side with my trunk's handle.
Offline oldsawfiler
  • COG#: 8062
cutting board
« Reply #2 on: September 03, 2008, 06:29:00 pm »
I think part of the problem is that I bolted the JCW to the board without using the mounting hardware that came with the trunk.  Maybe vibration.  I don't put much in it as far as weight goes.  I do store my helmet and gloves in it while at work.  But normally while riding it will just have some lunch stuff.  You know, a 6 pack, 4 sandwiches, 2 packs of twinkies, bag of chips. all light stuff. ;)    1990 Aint she a pretty Tomato (the bike ofcourse)  wedshots albums   http://community.webshots.com/user/sawfiler64/albums/most-recent
Offline 2linby
  • I rode today, did you?
  • COG#: 5539
cutting board
« Reply #3 on: September 04, 2008, 12:46:00 am »
Not to be the jerk, but as far as I am concerned cutting boards are designed for the kitchen. I think in the long run you will be better off buying a GIVI unit that is specifically designed for the bike and not the kitchen.  AKA "2linby" That's 2-lin-by folks!  Northwest Area Director  COG #5539  AMA #927779  IBA #15034  TEAM OREGON MC Instructor    http://community.webshots.com/user/2linby  http://tinyurl.com/njas8 (IBA BunBurner Gold Trip)  http://tinyurl.com/lwelx (Alaska trip)      Kindest Regards,Your Name. hehehe
Offline Rev Ryder
    • Presbychuck
  • COG#: 7235
cutting board
« Reply #4 on: September 04, 2008, 02:20:00 am »
I personally made an alluminum plate to bolt my JCW mount to.  It ain't gonna break.
Fortis non Ferox
 Shafties Can't Wheelie
Offline S Smith
  • Northeast Area Director
  • COG#: 3184
cutting board
« Reply #5 on: September 04, 2008, 08:41:00 am »
   I guess I missed this point with the topic heading, not realizing it was a kitchen cutting board.    Wooden cutting boards are generally made up of glued laminated strips of wood. The joints are structural weak points and the glue may not hold up when exposed to outdoor weather.       --  Steve Smith, #3184  COG Northeast Area Director  (somewhere in south central CT)    If you're not living on the edge, you're taking up too much space.
| Steve Smith | COG #3184 |
BECOME A COG MEMBER
Offline Rev Ryder
    • Presbychuck
  • COG#: 7235
cutting board
« Reply #6 on: September 04, 2008, 08:49:00 am »
Except the cutting board mentioned is a plastic one.
Fortis non Ferox
Offline Gerry B
  • Condoms prevent minivans!
  • COG#: 6037
cutting board
« Reply #7 on: September 04, 2008, 08:55:00 am »
What material was the cutting board made of? If it was wood, can you change the direction of the grain?      Ducati-The thinking mans V-Twin
Gerry Barnett
Enfield, CT
COG 6037
Offline norm-9688
  • COG#: 7011
cutting board
« Reply #8 on: September 04, 2008, 09:00:00 am »
I thought Murph had the best setup for the top boxes with his rail attachment kit...  CT AAD  COG #7011-A  2003 Concours-Mary Ann  1995 Honda Nighthawk 750 wifes
Offline Gerry B
  • COG#: 6037
cutting board
« Reply #9 on: September 04, 2008, 09:15:00 am »
Murph has the Shad trunks... I have one and really love it.  The mount it solid as hell.  But that's not the topic so I won't go off on a "you should bought..." tangent. Could you buy the mount for the Shad or a Givi and drill it to hold the JCW trunk?      Ducati-The thinking mans V-Twin
Gerry Barnett
Enfield, CT
COG 6037
Offline S Smith
  • COG#: 3184
cutting board
« Reply #10 on: September 04, 2008, 09:38:00 am »
   ok - I did not see that.      IIRC, the Givi mounting plate is designed to have what I can best describe as honeycomb ribs on the underside. These act as many I-beams that provide strength and rigidity to the mounting plate.     Doubling up on the plastic cutting board can help, but using taller vertical supports will offer more strength.   --  Steve Smith, #3184  COG Northeast Area Director  (somewhere in south central CT)    If you're not living on the edge, you're taking up too much space.
BECOME A COG MEMBER
Offline davedz
  • COG#: 8020
cutting board
« Reply #11 on: September 04, 2008, 09:51:00 am »
Another cutting board user here.  The metal plate for the JCW trunk will provide some rigidity and distribute the stress.  I also used the cross braces that came with the trunk as supports under the cutting board.  Changes are planned in my mount, mainly to include my helmet locks.  ..dz..  2003 Concours  1983 Honda Silverwing  2008 Yamaha Majesty (new)  2003 Honda XR70 (son's)
Cog# 8020/8020A
Locksmith
  • Guest
cutting board
« Reply #12 on: September 04, 2008, 09:51:00 am »
I did the dual cutting board mount for my JCW trunk.  I noticed several months down the road that the boards were sagging so I replaced them with two pieces of aluminum tubing.  I wanted the trunk moved a little further back.  06 Concours  Vancouver, BC
Offline oldsawfiler
  • COG#: 8062
cutting board
« Reply #13 on: September 04, 2008, 11:01:00 am »
Thanks for all the replys.  Yes it is plastic.  Bought another one a little thicker this time.  Will probably go to aluminum soon though.    1990 Aint she a pretty Tomato (the bike ofcourse)  wedshots albums   http://community.webshots.com/user/sawfiler64/albums/most-recent
Offline Desert Rider
  • COG#: 8095
cutting board
« Reply #14 on: September 11, 2008, 04:30:00 pm »
I did the double cutting board method (Target has them) and followed the instructions listed in this pdf: http://members.rennlist.com/jptl/Rack%20Procedure.pdf    It works well and looks good. Pay attention to all measurements and it will go together smoothly and securely, not to mention frugally!  I added spacer washers on the back between the 2 cutting boards and the base of the bike to progressively raise the rear angle of the top box so it doesn't look like it is falling off the back of the bike.  You can e-mail me if you want me to send pictures of my '06 with the JCW bag.
Offline Wess
  • COG#: 8010
cutting board
« Reply #15 on: September 11, 2008, 06:46:00 pm »
+1 on Chris.  I also secured it to the bike with some small steel cable to the antlers as I have heard of them falling off.  Respectfully Yours!  Wess Heavner  COG #8010 CDA #0239  [img]http://inlinethumb22.webshots.com/21909/2488051070102653285S200x200Q8
Respectfully Yours!
Wess Heavner
Independence, MO
Offline davedz
  • COG#: 8020
cutting board
« Reply #16 on: September 12, 2008, 08:40:00 am »
I mounted some blind 1/4-20 T-nuts underneath the cutting board and run some 1/4-20 bolts thru the trunk and mounting plate to secure it.  ..dz..    2003 Concours  1983 Honda Silverwing  2008 Yamaha Majesty (new)  2003 Honda XR70 (son's)
Cog# 8020/8020A
Offline Brett0769
cutting board
« Reply #17 on: September 12, 2008, 03:27:00 pm »
On this subject, I was looking at the OtP pics yesterday and saw a great big squared off trunk on a couple of the bikes. Does anybody know what trunk that is?
