Author Topic: Brake light modulator?  (Read 2015 times)
Offline Thud300
« on: August 13, 2015, 03:21:58 pm »
Recommendations on which one to install?
Leaning toward the Signal Dynamics wig-wag type, but it's spendy...  :(
1991 Voyager XII "Xaviera"
1989 454 LTD "Merlin"
Offline Outback Jon
  • COG#: 9506
Re: Brake light modulator?
« Reply #1 on: August 13, 2015, 03:33:07 pm »
Maybe a little spendy, but I got one and have been happy with it for years.  I put two strips of LEDs on my JCWhitney trunk and the wig-wag flashes them when I hit the brakes.  Definitely seems to get attention.
Offline MichiGlenn
  • "Wherever you are, be all there" Jim Elliot
  • COG#: 10892
« Reply #2 on: August 13, 2015, 09:24:44 pm »
I've had the $4.95 brake light strobe module from super bright led's on my C10 for a month or so. It does the job, easy to install.
2001 C-10
1977 Honda CB750K Sold
1978 Honda CB750K Long Gone
1972 Honda CL175 Ancient History
Heald Super Tryke 8hp, Wards T555 Trike
Offline Thud300
« Reply #3 on: September 22, 2015, 07:29:33 pm »
Settled on one for 20 plus ship on eBay. It's programmable for flash rate, number of flashes, duration of flashes and repeat cycling so you can get the effect you want. Made in USA  :great:, it's about the size of a nickel so it takes very little space to install.
With the LED brake lamps and extra brake lamp I have installed in place of the reflector, it's a nice addition for conspicuity, especially since much of my riding is at night.
Offline K-Hill
« Reply #4 on: October 02, 2015, 07:26:51 pm »
I have the 'Back-Off Wig-wag' on my ZRX 1200R (also a dual-bulb rear brake light) and I LOVE IT! It was under $40 but worth EVERY PENNY, and here's why I say that....
I went with the alternating flash connection option and as soon as my brake switch goes on (either front lever or rear pedal), the left and right alternate quickly 4 times, it goes solid for a 1/2 sec, then flashes both of them 3 times, and then stays solid until the brake is disengaged and resets the modulator.
I find this helpful since I usually have a decent gap between myself and the vehicle in front of me, so I lightly drag my brake to decelerate, but the flashing lights make sure the person behind me doesn't drift too close, EVEN if I tap the brake for just a sec.
My .02...
1999 in Candy Amaranth Red, 90k miles
« Reply #5 on: October 05, 2015, 05:30:46 pm »
Thud, after seeing your other post, you gave me an idea.
I ordered a flasher that works only on LED lights. (Yours is LED or Incandescent)
The (cheapo) LED only flasher cost $2.50.  So I decided to order it and give it a try.
My intention is to install it on the LED lights that are on my Trunk Bag.
If it works: The stock brake light will work as normal, and the Trunk Lights will do the flashing...
