Author Topic: Brake upgrade for Pre 1994 Concours  (Read 8078 times)
Offline 2fast
    • ZG Heat Shields
« on: February 23, 2013, 01:01:50 am »
More than a year ago, I got tired of mediocre brakes and warping rotors, and decided to do a full upgrade, including 320mm floating rotors and Tokico 4 pot calipers. The stock brakes for the pre 1994 Concours are a solid 270 mm rotor with a single pot caliper. I located a good match for the Concours hub size, bolt pattern and spacing, which turned out to be a rotor made for a 99-01 Yamaha YZF-R7, which used a modern full floating rotor. I purchased mine from a Chinese manufacturer that sells on Ebay named racingboy8261. The rotors go for a little over $200, and are sometimes marked even lower.
The 4 pot calipers I used are from a Kawasaki ZX6E which was made from 1993-2003. Lots of these calipers are available on ebay in a variety of condition. The missing link was the caliper adapter to mount the 4 pots to the stock fork legs.
Nothing is made to do this, so I had to design and make my own. I came up with a design, sourced a water jet cutter and had some made. They came out very nice, and surprisingly, they are lighter than the stock bracket. This despite the fact that the material is actually thicker than the stock items. The stock brackets weigh 10.6 oz each, and the ones I had made weigh 7.8 oz each. I don’t know what the caliper weight difference is, but likely they are pretty close. I did not do it for weight savings, but for better brakes. And better brakes is exactly what I got! I am currently using Kevlar pads, and they work quite well. I may change to an HH pad for more bite next time I need pads. The trade off is more rotor wear with the HH pads.
The other modifications needed for this to work are fairly simple. The new 320 rotors mounting holes are too small, so they need to be drilled out to a 10mm hole. Easy. The calipers have a step in the mating surface that needs to be removed, and then the whole mating surface milled down so it is 2.5mm below the pad surface. The calipers have threaded holes which also need to be drilled out to 10mm. This is because with the new bracket, you are bolting through the caliper into the bracket. The bolts needed are a 10mm flange bolt, 1.25 pitch in a 20mm length, available at hardware stores. The fork leg mount uses the stock bolts, which are the same thread type and size.
Bolt it all together, and enjoy braking that is on par with most modern bikes! I have put more than 10,000 miles on this new setup and it works great. This link http://s1337.beta.photobucket.com/user/bpsnow1/library/C10%20BrakeUpgrade%20bracket       shows photos of most of the process to help make things a bit easier to understand. Since I had to pay the jet cutter to set up cad drawings and make the brackets, I went ahead and had some extra sets made. If anyone would like to do this upgrade, I’ll send you a pair of brackets for $80, shipping included. I have not had any isses, but I leave it to you to decide if you can do the work and if it will function properly on your bike.  Oh, forgot to mention that I powdercoated the brackets lightly with matte black.
« Last Edit: February 24, 2013, 02:35:13 pm by 2Fast »
Brian in Minnesota
Re: Brake upgrade for Pre 1994 Concours
« Reply #1 on: February 23, 2013, 01:11:45 am »
Excellent Brian! Long live the c-10! Steve
Offline Capo
  • Greasy Side Down
  • COG#: 10810
« Reply #2 on: March 22, 2013, 10:44:13 am »
I am certainly interested in these for my 86. I had been considering re-doing the whole front end, but for now anyway I just want to upgrade the brakes. Is pay pal best for you? I would like them shipped to 34606. Thanks
James in Tampa. Currently being enjoyed are...04 C10,  86 C10 "Cooper" , 04 Honda vt750 "Christine" . The  only previously owned needing mention would be 74 gt750, I cant believe how many of us had a "water buffalo" !!!
« Reply #3 on: March 22, 2013, 01:32:10 pm »
Capo- I have a set here for the tech session, for show and tell. I'm sure you can pay Brian for them and they're yours - Steve
Offline Capo
  • Greasy Side Down
  • COG#: 10810
« Reply #4 on: March 22, 2013, 03:25:05 pm »
 :-\ Thats great, ill take em!
Offline 2fast
    • ZG Heat Shields
« Reply #5 on: March 22, 2013, 08:52:19 pm »
Capo, PM sent :great:
Brian in Minnesota
Offline 2fast
    • ZG Heat Shields
« Reply #6 on: March 22, 2013, 09:58:04 pm »
Pm'd  from Airmonger
PM'd you and Capo back!
Brian in Minnesota
Offline RWulf
  • COG#: 7122
« Reply #7 on: March 22, 2013, 11:05:37 pm »
Nice work Brian. After I got into doing mine I was surprised how easy it was.
I can see where you got the weight saving, I left mine more or less a triangle
shape. All in all good job.
rwulf
Offline 2fast
    • ZG Heat Shields
« Reply #8 on: March 22, 2013, 11:35:33 pm »
Thank you Richard :great:
Airmonger....I need your mailing address.
Brian in Minnesota
Offline Capo
  • Greasy Side Down
  • COG#: 10810
« Reply #9 on: March 29, 2013, 12:25:37 am »
 :great: thanks 2fast. Got my adapters and I'm impressed with the quality. Your instructions / info on this thread is great  too. I have been looking at rotors and it looks like the r7 for the yrs. you mentioned were used on the late model fjr1300 also! If you find that I am wrong would you please let me know tho.  Thanks
Offline 2fast
    • ZG Heat Shields
« Reply #10 on: March 29, 2013, 01:56:21 am »
Thanks James.......got your pmt too. It looks like you are correct on the rotor interchange. According to the ebay seller I bought from, the same rotor fits these:
YAMAHA FJR 1300CC model year 2004-2006
YAMAHA FJR 1300CC model year 2007-2009
YAMAHA FJR ABS (RP08/) 1300CC model year 2003-2005
I think I mentioned he has them on sale from time to time, and right now is one of those times. 15% off makes em $195.50 right now, and shipping is free! http://www.ebay.com/itm/310261175803?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
I look forward to hearing how the upgrade goes once you get all the bits assembled.  :great:
Brian in Minnesota
Offline 2fast
    • ZG Heat Shields
« Reply #11 on: March 30, 2013, 02:14:32 am »
Sounds like you are on the way AirMonger. Have you got rotors located yet?
Brian in Minnesota
Offline 2fast
    • ZG Heat Shields
« Reply #12 on: March 30, 2013, 04:11:43 pm »
I think the wave rotors set off my pink jacket nicely, but maybe that's just me.......
Brian in Minnesota
Offline Capo
  • Greasy Side Down
  • COG#: 10810
« Reply #13 on: March 31, 2013, 12:09:26 am »
Not to mention your bell and flower basket on the front :rotflmao:
Offline 2fast
    • ZG Heat Shields
« Reply #14 on: April 03, 2013, 01:08:12 am »
No one will judge.... :-\
Brian in Minnesota
Offline GF-in-CA
« Reply #15 on: April 03, 2013, 02:16:50 am »
Brian, this looks like a great mod, good job following through on this  :great:
There are a few more motorcycles that you can add to the list of caliper donors:
ZX7 1991-95
ZX9B 1994-96
ZX11D 1994-2001
There are probably more, but these are the ones I know for sure.  These bikes all used the same type of Tokico caliper as the ZX6E.
HTH,
Gary F.
1998 ZGX1100
Central Valley California
Offline 2fast
    • ZG Heat Shields
« Reply #16 on: April 05, 2013, 01:53:40 am »
ZX7 1991-95
ZX9B 1994-96
ZX11D 1994-2001
HTH,
Hey Gary, Thanks for the kind words and for adding to the caliper donor list! :great:
Brian in Minnesota
Offline 2fast
    • ZG Heat Shields
« Reply #17 on: April 05, 2013, 01:54:50 am »
Recieved my rotors tonight. Man, quick if I do say so myself. I have had slower deliveries from within the good ole USA. Guess I need to get busy, but as usual just in time for an outage at the plant. Life is not fair. :truce:
And so it goes........I look forward to hearing you have them installed :)
Brian in Minnesota
Offline 2fast
    • ZG Heat Shields
« Reply #18 on: April 08, 2013, 02:05:46 am »
Wow! You got right on it :-\  Looks great, and glad to hear you are liking the difference. I'm curious what you did for brake pads. Did you go kevlar or  HH sintered?  How about the rotors......are they new or used? I'd love to see a close up shot. If you only have 20 miles on em, the best is yet to come.
« Last Edit: April 08, 2013, 02:07:50 am by 2Fast »
Brian in Minnesota
Offline xjdaver
  • COG#: 9271
« Reply #19 on: April 29, 2013, 01:57:56 am »
Has anyone brought in their calipers in for the required milling? Just wondering what that would cost.
87 ZG1000
82 Yamaha XJ550R
Offline 2fast
    • ZG Heat Shields
« Reply #20 on: April 29, 2013, 02:32:38 am »
My set was milled for free by a friend. I can see that an experienced carpenter with enough sense and precautions could actually do this milling with a table saw running a carbide blade. Aluminum comes off easy.........but you gotta know what you are doing to avoid a serious and potentially catastrophic disaster. Metal flying at a high rate of speed could maim or kill you.
The safer option is to have a mill operator do it for you. It would be cool if we had a COG machinist that could do this operation for folks wanting to do the upgrade.  Anyone??
Brian in Minnesota
Offline 2fast
    • ZG Heat Shields
« Reply #21 on: May 05, 2013, 12:58:14 am »
Mmmmmmmmmm, stopping good :great:
Know what you mean about the front springs....if you have stockers. I'd either cut and space the existing springs or do a set of Sonics.
Right now I still have Kevlar pads installed. I started with them to be easier on the rotors and a less abrupt transition from the original setup. I'm gonna do HH's if/when this set wears out.
Thanks for the update, I'm glad to hear you are lovin em :)
Brian in Minnesota
« Reply #22 on: May 05, 2013, 01:50:47 am »
Brian - looks like the adapters are going to be a weiner! ;)
 So I was wondering what you think about the kevlars. I have hh sintered ebc's on my fronts now. How does the kevlar compare? Easier on the rotors? wear rate? Performance in water? You know when riding at my level brake performance is crucial (since I'm to scared to really lean)  :rotflmao:  :-[  Steve
Offline 2fast
    • ZG Heat Shields
« Reply #23 on: May 05, 2013, 02:35:43 am »
Here's my take on the two. I think the Kevlar is much easier on the rotors. Honestly, you can barely tell mine are not new. They stop the bike very nicely, no grabbing, especially compared to the stock setup.
I think the wet braking is better than the HH's. I think sintered (HH) will do better than the Kevlar when dry. Grooving, wear and brake dust are worse with HH.
Wear rate? I don't really know which one goes away faster.
Brian in Minnesota
Offline Scoobys_piece
« Reply #24 on: June 23, 2013, 09:44:31 pm »
Are these still available???  Hope so. Please contact me at your convenience. Thank you for offering these and hope they are still in stock....SCoob
