Author Topic: Chinese Pazzo lever knockoffs  (Read 9259 times)
Offline Easy13
  • '05 ZG1000 Concours "Harlow's Revenge"
  • COG#: 11001
« on: July 08, 2013, 10:51:35 pm »
A few years back, my wife bought a set of genuine Pazzo levers for my Triumph ($179, and yes, she is fabulous).  Of course, about 20 minutes after they showed up, eBay started listing knockoffs for about $30.
Well, I like those Pazzos very much, so I decided to try the Chazzos on the Connie.  Took a while for them to get here, but they're very nice, they fit perfectly and mounted right up in a couple minutes.  The main attraction of this type lever is the fine adjustments to move the lever into a position that's "just right".  Were the Pazzo levers worth $179?  Not really, though they are Pure Motorcycle Decadence.  For around $30 though, the "Chazzos" are very nice indeed, and there're LOTS of color choices!
http://www.ebay.com/itm/170836082190?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
DISCLAIMER:  No, I'm not getting any backhanders from Hong Kong, I just wanted to pass on a good deal to my fellow COGers.
Titanium colored lever, black adjuster, regular length.
« Last Edit: July 08, 2013, 10:54:35 pm by Easy13 »
Cognito Ergo Wrenchum
Re: Chinese Pazzo lever knockoffs
« Reply #1 on: July 08, 2013, 11:06:58 pm »
Nice, at 30 some odd bucks.
Is there a notch in your lever, or am I seeing things in your pic?
Edit: Indeed, looking at some of the listings on e-bay, there is a notch, I guess to prevent damage to the master in the event the lever contacts the ground:
« Last Edit: July 08, 2013, 11:11:24 pm by WillyP »
Offline mattchewn
  • COG#: 10993
« Reply #2 on: July 08, 2013, 11:27:28 pm »
OOOOOOOHHHHHH!   SHINY!!!!
2018 H2 SXSE.  (FAT SXSE)
2011 GSX1250 FA
2009 Ninja 500R. (wifes')
2001 Bandit 650  (kids')
« Reply #3 on: July 08, 2013, 11:50:18 pm »
The notch allows the end to break off in a tip over or light crash. It may allow you to still have a lever to get you home.
« Reply #4 on: July 08, 2013, 11:55:17 pm »
That happened to me this spring and I rode it home with the brake lever bent about 90degrees... made left turns in the parking lot very tricky!
Offline PaleRider
« Reply #5 on: July 09, 2013, 12:42:10 am »
Matt,  lol  love it.
Have Owned 2004 Honda VFR, 2004 Honda ST1300, 2000 Triumph Sprint ST.
Now 2012 ZG1400 in Pearl Arabian Red
Offline Bruiser
  • Bruiser
« Reply #6 on: July 12, 2013, 06:35:53 am »
I had a set on my old C10, and really liked the feel of them
« Last Edit: July 13, 2013, 03:51:31 am by Bruce »
Bruiser
2012 Kawasaki C14
93 Kawasaki C10
1982 Honda CX500 Turbo
1980 Kawasaki KZ1000ST
1978 Honda CB750F
1976 Kawasaki KZ400
1976 Honda 750K
1973 Honda CB500K
1973 Honda SL175
1972 Honda SL125
Offline worncog
  • COG#: 9584
« Reply #7 on: July 12, 2013, 12:26:59 pm »
And to think I thought I was almost done farkling...
Thanks Easy. Looks like a decent deal for 30 bucks.
RWTW, COBDR, SM 500, BVF...
Offline Edward
  • COG#: 10829
« Reply #8 on: July 20, 2013, 04:57:08 am »
Darnit!
My 'inexpensive bike' isn't so inexpensive if this keeps up...
 :truce:
Good thing I love this damn thing!
 :great:
Offline SteveJ.
  • COG#: 5603
« Reply #9 on: July 20, 2013, 11:13:56 am »
Question for someone that has these, is there a brass insert at the pivot point? It doesn't appear that they have any kind of bushing there.
Tick Tock, baby (Ironbuttal)
Offline Easy13
  • COG#: 11001
« Reply #10 on: July 20, 2013, 02:21:26 pm »
No brass, but my stockers didn't have it either.
« Last Edit: July 20, 2013, 02:24:11 pm by Easy13 »
« Reply #11 on: July 20, 2013, 03:44:38 pm »
Stockers do have brass inserts.
They wear out and get sloppy. I pressed mine out and turned them 45 degrees. Now they are not sloppy.
I also  have the very same Pazzo knock offs. I like them.
I remember having to do a little bit of grinding to the return limiter on the lever where it hits the switch.
Offline SteveJ.
  • COG#: 5603
« Reply #12 on: July 20, 2013, 06:21:08 pm »
I would concur.
Offline SamSam
  • COG#: 6191
« Reply #13 on: July 23, 2013, 02:02:49 am »
Question to anyone using these.  Just installed a pair.  The brake went on with no problem.  Did not use the brass insert from the OEM.  The clutch was a problem if you use the stocker bushing with the hole that the clutch pushrod inserts into.  It goes on OK without it.
My question to anyone using these is are you using the stocker clutch bushing with the hole that the clutch pushrod fits into or did you install without it? Any issues operating without it?
Sal Sammartino
COG #6191; AMA #1107290
2015 VFR800D; 2006 C10; 2001 C10 (lost in fire!); 2009 Honda Metro 50; 2011 buddy 125
If you didn't have a good time its your own fault!
Offline Hazy
  • COG#: 10534
« Reply #14 on: July 23, 2013, 02:30:08 pm »
ewwww...the blue would go well with the Sonic Blue. :)
North Central Area
COG#:10534
Offline vanjeff
  • COG#: 10695
« Reply #15 on: July 23, 2013, 10:32:04 pm »
See, I wasn't sure whether it would be the blue, or the chrome for the sonic blue........
Just go ahead and order them, I will live vicariously through you, and then after you post pics, i will order. :)) :)) :))
Offline Hazy
  • COG#: 10534
« Reply #16 on: July 24, 2013, 03:47:33 am »
They're only 30 bucks...Im half tempted. I must ponder upon this further.  >:D
North Central Area
COG#:10534
Offline virtualdev
  • Ride.all.year.
  • car broken, ride all winter
    • The Borked Universe
« Reply #17 on: July 24, 2013, 03:25:32 pm »
I'm kind of tempted too.  Need to wait for my J-Box to come back and make sure I don't need to spend more money to keep it running.  Then...farkles!
I'd love to go a color, but I'm also thinking about repainting... *ponders*
Offline Def
« Reply #18 on: July 31, 2013, 04:12:05 am »
+1 on the Chazzos. I had a pair on my last bike and really liked them. Some complained about the colored ones fading over time. I had the shiny silver ones with a black adjuster and it did not fade. The adjustability was great! FWIW.
Offline dkwracer
« Reply #19 on: August 25, 2014, 03:50:00 pm »
Hi, will those fit a 1987 c10?
« Reply #20 on: August 25, 2014, 09:06:42 pm »
all C10's had the same levers
Offline worncog
  • COG#: 9584
« Reply #21 on: August 25, 2014, 11:47:23 pm »
Been running a pair for a few months now. Work good, cheap, very adjustable on the fly.
Offline Kawa-Leon
« Reply #22 on: August 27, 2014, 01:53:31 am »
I use the stock busing.  Did need a little press to get it in.  Hope you give it another try.
Like the clutch side especially; saving lots of efforts to pull in the level.
Offline LessPaul
    • Tim Perry Creative Services
« Reply #23 on: September 05, 2014, 12:34:21 pm »
These are sold as pairs?
1971 Honda CB350 (in '76)
Time passes. Like 35+ years
1986 Kawasaki Concours (in '13)
Life is once again as it should be.
Offline worncog
  • COG#: 9584
« Reply #24 on: September 10, 2014, 03:15:44 pm »
