Author Topic: Clear Front Turn Signals for 2006 C10  (Read 5467 times)
Offline Bluezone
  • COG#: 11568
« on: May 28, 2016, 12:04:17 pm »
Has anyone sourced these clear front turn signal lens from any other supplier than K&S Technologies?
http://www.kandstech.com/pimages/25-2212.html
The amber lens are all over the place, very common, the clear lens are listed as part numbers 25-2211C and 25-2212C. But ordering the clear lens is turning out to be a nightmare    >:(  (if you ask me, maybe this is the norm?).
K&S seem to deal only with Parts Canada/Part-Unlimited/Drag Specialties distributors. Every dealer I have called (one from all 3) just say its not in the catalog, we can't get it. After contacting Parts-U international sales myself, they contacted the dealer themselves and finally worked out a process that will at least finally get me a price, but really, why is this so hard?
To me there seems to be a big market for clear lens, given the advancement in LED automotive bulb tech, this could double as a DRL and amber turn signal.
Offline Edward
  • COG#: 10829
Re: Clear Front Turn Signals for 2006 C10
« Reply #1 on: May 31, 2016, 09:14:16 pm »
You manage to get a good part number, place an order and take delivery, I would be interested.
Following.
Offline Rev Ryder
    • Presbychuck
  • COG#: 7235
« Reply #2 on: June 01, 2016, 01:39:48 pm »
I guess I could make some, but not till after the National.  It'd take a couple of days to prototype and mold them and a little destructive testing of an existing amber set.  If I was doing that I might as well make rear lenses and tail ones too.
Fortis non Ferox
 Shafties Can't Wheelie
Offline millerized
  • Sacred Cow Stomper
  • COG#: 6425
« Reply #3 on: June 01, 2016, 02:58:49 pm »
I'm in for a clear tank when you're done.
Millerized aka RainMan
As politically incorrect as you can get without a warning label or license.
CDA111
« Reply #4 on: June 01, 2016, 04:45:02 pm »
 :rotflmao:
Offline millerized
  • COG#: 6425
« Reply #5 on: June 01, 2016, 05:52:49 pm »
:rotflmao:
Whut...at least I'll know how much fuel there is left.
CDA111
Offline Rev Ryder
    • Presbychuck
  • COG#: 7235
« Reply #6 on: June 01, 2016, 11:44:49 pm »
Jimbo, get in the back of the line.  No cuttin'.
Fortis non Ferox
Offline Bluezone
  • COG#: 11568
« Reply #7 on: June 02, 2016, 01:03:33 pm »
The clear ones for the rear signals are readily available, I just bought a pair from Ebay, 25-2040C. The front part numbers are valid, its just whether or not K&S will make and ship them at a reasonable cost. It could be another 3 weeks before I know.
Offline Nosmo
« Reply #8 on: June 02, 2016, 02:16:45 pm »
This guy maybe able to set you up:
pic below:
2003 Connie    2007 Wee-Strom
Offline millerized
  • COG#: 6425
« Reply #9 on: June 02, 2016, 04:06:36 pm »
:29:
Nosmo hooked me up
:29:
CDA111
Offline Rev Ryder
    • Presbychuck
  • COG#: 7235
« Reply #10 on: June 02, 2016, 09:13:04 pm »
So he did. Not sure Pyrex is the material of choice for fuel cells, but it IS see through. LOL
Can you say, Molotov Cocktail?
Fortis non Ferox
Offline mf-rabbit
  • COG#: 9851
« Reply #11 on: June 05, 2016, 10:38:08 am »
I've got the marshmallows and graham crackers :great:
        Roger
Offline Rev Ryder
    • Presbychuck
  • COG#: 7235
« Reply #12 on: June 05, 2016, 10:58:02 am »
Don't know if they still do, but stations all once said, "no gasoline in glass containers."  :o
Im sure there is something, but any plastics that I know off that can be made clear would either be damaged by the fuel (stained or even melted) or by UV rays.  Glass can take both of those but is a tad fragile.  There's probably a water-clear resin that could be used with fiberglass to create a near clear tank with some strength. But typically you'd have to line it to protect the resin from the fuel. You'd need a clear POR15 to put in there.  ;D
For tail lights there are a number of epoxy and urethane resin options that would do a great job.  Or you could injection mold them, but that's bit harder to do at home and molding for it is quite expensive.
« Last Edit: June 05, 2016, 11:06:52 am by Rev Ryder »
Fortis non Ferox
Offline Jorge
  • COG#: 9297
« Reply #13 on: June 12, 2016, 05:34:04 pm »
Depending on why you want the clear front lenses, you might just get the amber LEDs
 From what I've read, amber lenses don't reduce the brightness of amber LEDs much, if at all.
Of course, if you want clear for aesthetics reasons then only clear will do.
Remember to use the right type if flasher if you do go LEDs.
I bet you could find LEDs that are much brighter than the current incandescent bulbs  :great:
Jorge
Offline Outback Jon
  • COG#: 9506
« Reply #14 on: June 12, 2016, 06:15:17 pm »
I did.  Unfortunately, the design of the front turn signal reflectors and housings negate the improvement.  They work wonderfully in the rear brake and rear turn signals, though.  I still installed them in the front because I like how the LEDs "light up" vs stock.  But they really are pretty much the same brightness as the stock.
Offline Bluezone
  • COG#: 11568
« Reply #15 on: October 25, 2016, 12:38:01 pm »
I received them last week and installed them on the weekend. I have not had any luck posting pictures so I will only post text to see if that works. One thing is with the dual LEDs I got off Amazon they are BRIGHT! Almost to the point where I don't need the headlight. The outcome was as I expected and I'm happy with the mod.
Offline Bluezone
  • COG#: 11568
« Reply #16 on: October 25, 2016, 01:01:45 pm »
Some pictures.
Offline Rev Ryder
    • Presbychuck
  • COG#: 7235
« Reply #17 on: October 25, 2016, 05:23:05 pm »
Nice.
Fortis non Ferox
Offline BuckwheatJ
  • No good deed goes unpunished!
  • COG#: 11799
« Reply #18 on: October 25, 2016, 08:21:11 pm »
So who did you end up ordering them (the fronts) through?
1978 KZ1000 Z1R
2004 Z1000
2005 ZG1000
Offline Bluezone
  • COG#: 11568
« Reply #19 on: October 26, 2016, 12:07:02 pm »
I had to order them through the only Parts Unlimited dealer in Canada, Bayside Performance in BC. The LED's were ordered via Amazon. The Lens took 5 months to get.
Offline HSVScott
  • HSVScott
  • COG#: 12376
« Reply #20 on: October 27, 2016, 12:06:40 am »
Did you order them via the web?  if so, do you have a link?
Offline Bluezone
  • COG#: 11568
« Reply #21 on: October 27, 2016, 08:31:26 am »
I had to call the Parts Unlimited dealer, they are special order, the site posted in in my 1st message has the part numbers.
Offline Bob_C_CT
« Reply #22 on: October 27, 2016, 09:49:02 am »
Bluezone, trying to figure out from your pics. You have the clear signals and dual LEDs , one white for running lights and one amber when you use the signal? Two bulbs or is there a single bulb offered with both colors?
I think what's throwing me off is the last pic, that must be a pic of the stockers before the mod.
I like the white running lights for alerting cagers ahead of my presence.
 The kit they offer looks just to be amber bulbs so that is why you went with dual? element, white and amber bulb(s) from Amazon?
Southern Connecticut.
Offline Bluezone
  • COG#: 11568
« Reply #23 on: October 27, 2016, 12:10:22 pm »
Good point, some detailed descriptions;
Pic 1 - this is clear lens installed, LEDs not on.
Pic 2 - this is clear lens with new LEDs on.
Pic 3 - this is clear lens, c/w amber 1157 bulb and socket and the LEDs I got from Amazon
          p/n JDM ASTAR-1157-PX-28WY.
Pic 4 - this is the factory amber lens with origial bulb in left and new LED IN right to show difference in          brightness.
The LEDs are dual White/Amber and will replace an 1157 standard dual element bulb. The white turns off in turn mode as well.
The turn flash rate is quicker and I did buy some resistors but the funny thing is when they are in hazard mode the flash rate is slower almost what I would consider normal, the flasher unit must be wired differently than the signal circuit.
I had some vids but they are too large to upload.
Bluezone
Offline Cal
  • COG#: 12008
« Reply #24 on: October 27, 2016, 02:03:12 pm »
Bluezone
Pic 4 is white running light only (not flash/amber led?)
by any chance did you get a flash on picture?  it would have been nice to see the difference between the white running light vs amber flash in the original amber lens.
what price were the clear lens (pair)?
Cal
