Author Topic: Clear Front Turn Signals for 2006 C10  (Read 5612 times)
Offline Bluezone
  • COG#: 11568
Re: Clear Front Turn Signals for 2006 C10
« Reply #25 on: October 27, 2016, 02:13:54 pm »
Correct, pic 4 is lights in running mode, to compare brightness,  In my opinion the LED is much brighter even with the amber lens. send me an email addy and I will send you a vid of flashing mode.
My cdn cost was about $45 each, plus tax plus shipping, not much more than what the amber lens can be found for on ebay, etc
Offline Jim
  • Jim
« Reply #26 on: October 27, 2016, 02:26:28 pm »
Your hazard lights flash slower because your flasher is working with a greater load (closer to what it expects to see).  Four bulbs instead of 2 bulbs.  Thermally activated flashers have a min and max lamp capacity for proper operation.
« Last Edit: October 27, 2016, 02:29:29 pm by Jim »
Offline Bluezone
  • COG#: 11568
« Reply #27 on: October 27, 2016, 02:39:45 pm »
I'm going to leave it as is, the turn flash rate is faster but not so fast as to interfere with the idea of which way I want to turn.
Offline Cal
  • COG#: 12008
« Reply #28 on: October 27, 2016, 03:30:46 pm »
Bluezone
PM with email address sent.  I think I could be happy with leaving the amber lens in place as long as the differential between white running and amber flash is significant enough.  I don't know how they get the white running light to stay off between amber flash events.
never knew anyone made the white/amber combos - nor the clear lens either (:>
with electronic flashers available - I don't know why people begin to try using the load resistors!
thanks
Cal
Offline HSVScott
  • HSVScott
  • COG#: 12376
« Reply #29 on: October 27, 2016, 11:18:25 pm »
I had to call the Parts Unlimited dealer, they are special order, the site posted in in my 1st message has the part numbers.
Do you have the number for the Parts Unlimited dealer?  Also, did you happen to note the name(s) of anyone you dealt with so they would know what to do?  you can PM that to me if you wish.  Thanks!  I love the idea, your bike looks cool.
Offline Bluezone
  • COG#: 11568
« Reply #30 on: October 28, 2016, 08:43:05 am »
K&S Technologies
25-2211C
25-2212C
If you are in Canada then contact Bayside Performance in BC, and If you are in the US contact any Parts Unlimited dealer.
Bayside Performance in Vancouver, BC,
604-325-2252.
« Last Edit: October 28, 2016, 10:13:14 am by Bluezone, Reason: Typo »
Offline Nosmo
« Reply #31 on: October 28, 2016, 01:43:38 pm »
Here's an interesting report on running lights:
http://www-nrd.nhtsa.dot.gov/pdf/esv/esv19/05-0178-w.pdf
2003 Connie    2007 Wee-Strom
Offline Bluezone
  • COG#: 11568
« Reply #32 on: October 28, 2016, 05:06:05 pm »
From the manufacturer of the LEDs I used;
Raw lumens from white is 1200,
Raw lumens from amber is 800.
Offline coffee_brake
  • COG#: 7653
« Reply #33 on: October 29, 2016, 12:24:37 am »
Those are SWEET! I want some!
