Author Topic: Great dash mount for my Droid X or any accessories..  (Read 1100 times)
Offline Dano
  • COG#: 9627
« on: July 19, 2011, 12:26:07 am »
I got in my dash mount so I can mount my Droid X as my GPS,MP3,Phone. Picked up a small Ram mount base that has a built in round adhesive disc that is a perminate part of the mount not useing a suction cup attachement that never hold up. Then the custom mount for the Drois X in an Otter Box Defrender bolts to the base. It all fits between the dash and the Rifle base giving it a bit of protection. Looks like it belongs there.
I stuck it to the under side of the rifle base thinking it would get less vibration as the dash bounces around a bit but we will see hoe the adhesive holds up to being "hung" which of course puts more pressure on the mount but we will see.
Dano59 COG#9627 CDA#0358
Charleston, Illinois
92 Concours (93 Color for some reason)
www.jacksonavenuecoffee.com
www.harpart.webs.com
Offline SAS Mayhem
  • COG#: 9199
Re: Great dash mount for my Droid X or any accessories..
« Reply #1 on: July 19, 2011, 06:58:38 am »
Looks good Dano.  ;)
Cheers
Ron
COG & AMA Member
06 C10
09 C14
try to live a day without doing one of the 5 D’s....Deny, Defer, Deflect, Discount and Deceit...tougher than it sounds....
Offline Dano
  • COG#: 9627
« Reply #2 on: July 19, 2011, 07:06:34 am »
I guess it would have looked better with the Droid X in place but that's what I took the pic with :)
Offline oldsawfiler
  • COG#: 8062
« Reply #3 on: July 19, 2011, 02:03:18 pm »
I mounted a NUVI 750 in the same maner except I drilled the base and bolted the RAM base to the Rifle.  It has been there for 4 years.  I did put some velcroe on the shelf and the bottom of the GPS.  It was not necisary.
Can you acsess the Droid functions through the box?
Offline Dano
  • COG#: 9627
« Reply #4 on: July 19, 2011, 02:54:04 pm »
Yes the Otter box is what I have the phone in all the time. Covered 100% including a hard plastic screen cover. The connection ports are covered with rubber doors that fold out of the way if access is needed and all buttons are covered but useable, Works great. I thought about drilling for a base but thought I would try this first.
Offline Dano
  • COG#: 9627
« Reply #5 on: July 19, 2011, 03:01:21 pm »
Here is a pic of mount
