Author Topic: Dash Shelf Vibration  (Read 3240 times)
Offline Far2Ride
  • NICE MOTORCYCLE SHIRT. WHERES YOUR BIKE?
  • Far2Ride.com
    • Far2Ride
  • COG#: 12191
« on: May 03, 2016, 11:52:50 pm »
Anybody come up with anything to cut down on some of the shelf/ fairing vibration. I understand it can't be totally eliminated but?????????? Before I get the Mr. Obvious answers I would like to keep both GPS units up there. Thanks.
Cold, Rain, Heat and a BUNCH of miles every year. THE DIFFERENCE BETWEEN MOTORCYCLE OWNERS AND MOTORCYCLE RIDERS!
Offline Pat and Sher in MA
  • COG#: 7670
Re: Dash Shelf Vibration
« Reply #1 on: May 04, 2016, 12:16:39 am »
Check main fairing bolt on steering head for wear and tighten/replace if needed.
Pat & Sher in Ma.  04 C10 Dark Angel,  87 Ninja 600RX
Offline RWulf
  • COG#: 7122
« Reply #2 on: May 04, 2016, 07:39:30 pm »
Yep Pat & Sher are right on. If it is tight check the end
of the stay also.
« Reply #3 on: May 04, 2016, 07:46:11 pm »
Not just the bolt, but the bracket it bolts into. The piece welded to the steering head tube can break even when the bolt is good and is tight.
But, if your shelf is vibrating more than the fairing it might just need to be stiffer. Or do you mean vibration transmitted from the fairing? In which case it might be too rigid.
« Last Edit: May 04, 2016, 07:54:04 pm by WillyP »
Offline VTconnie
  • COG#: 11081
« Reply #4 on: May 04, 2016, 10:03:05 pm »
I see the need for radar, because what guides the missiles otherwise?  :)
Offline Larry_Buck_FL
    • Buck Sport Touring
  • COG#: 3451
« Reply #5 on: May 05, 2016, 11:32:58 am »
By all means check the main fairing bolt. Also a loose front fender can sound like it's coming from the shelf. You'll need washers on each side of the fender to make it snug again. I also had not tightened the RAM base to the shelf (doh!) which caused a banging noise because the GPS was contacting the shelf. HTH
Offline Stasch
  • COG#: 6830
« Reply #6 on: May 05, 2016, 03:13:00 pm »
Check the left and right main fairing mount points to the frame as well.  Near the bottom front of the fuel tank.
Just helped a fellow COGGER go through his C10 and one of those was completely missing.
His fairing was bouncing around a lot before it was replaced.
Stan Visser - COG#: 6830
  • COG#: 7670
« Reply #7 on: May 10, 2016, 03:29:36 am »
Far2Ride,
Any updates on the shelf vibration issue? Just wondering if any of the fairing mount bolts were loose
or even missing/broken?
Thanks  :great:
Offline Far2Ride
  • Far2Ride.com
    • Far2Ride
  • COG#: 12191
« Reply #8 on: May 10, 2016, 09:46:50 pm »
Far2Ride,
Thanks  :great:
Everything checked out good. Figured out with both GPS units mounted up there the 7" was causing a little more flex in the shelf I think due to the weight and length of the ram mount arm. Machined a piece of plastic that supports the arm at the front edge of the shelf and all is good. Not a dig on the Bucks shelf (good quality piece) I just have a lot mounted on it.
  • COG#: 7670
« Reply #9 on: May 10, 2016, 10:18:49 pm »
Far2Ride,
Glad you were able to come up with a solution for the mount issue. Thanks for
the update.  :motonoises:
Offline John_Atkinson
  • COG#: 5921
« Reply #10 on: July 02, 2016, 06:34:29 pm »
Anyone have a pic of what this section is SUPPOSED to look like?
John Atkinson
Windsor, ON
CANADA
COG #5921
  • COG#: 5921
« Reply #11 on: July 20, 2018, 08:16:37 pm »
John Atkinson
Windsor, ON
CANADA
COG #5921
Offline esmoojee
« Reply #12 on: July 21, 2018, 12:44:15 am »
My main bracket broke like the pics above AND someone removed the lower brace bolts from the side of the engine. I replaced those and came up with a quick solution that someone on the Facebook page suggested with band clamps. Now it doesn’t vibrate at all. I’ll have the tab re-welded when I have the time.  :)
Offline oldsmoboat
  • 2004 C10
  • COG#: 11969
« Reply #13 on: July 21, 2018, 11:52:50 pm »
I ran a strap from the shelf to the screw at the top of this (not mine) picture.
http://farm6.staticflickr.com/5470/9680671129_092c38b23c.jpg
