By all means check the main fairing bolt. Also a loose front fender can sound like it's coming from the shelf. You'll need washers on each side of the fender to make it snug again. I also had not tightened the RAM base to the shelf (doh!) which caused a banging noise because the GPS was contacting the shelf. HTH
