Author Topic: Gaiters Installed  (Read 1437 times)
Offline KIKKER
  • Rockin' It Ole School
  • COG#: 10536
Gaiters Installed
« on: December 03, 2012, 11:29:54 pm »
Gaiters installed-
They are pretty cool-Large at bottom & tapered to top.
Might have to shorten-
Do I have the speedo cable guide installed correctly?
1955 Cushman Eagle
1987 Concours
2001 Special Construction Rat Beast
2010 Ural Patrol Side Car Rig
Offline ron203
  • COG#: 9847
Re: Gaiters Installed
« Reply #1 on: December 03, 2012, 11:48:03 pm »
Cool old school. Where'd you get them and that idea?
2014 C-14
2008 Goldwing
Offline wild man
  • COG#: 6174
« Reply #2 on: December 04, 2012, 12:20:11 am »
I cant tell at the wheel.  However at the frame I ditched that wire clip on the lower triple clamp years ago.  I fastened the speedo cable directly to the black frame tube with a heavy duty black zip tie.  The cable makes a nice straight line up to the speedo.  The zip tie has been there for seven without fail.
Bill
USAF Ret, KC0IGL
AMA#333772, IBA#19247
2007 KLR 650, 1997 ATK 605
Offline GeorgeRYoung
« Reply #3 on: December 04, 2012, 12:52:11 am »
If you don't want severe binding when the forks are compressed, you'll probably have to shorten the gaiters. Here's a suggestion for supporting the top after cutting:
http://web.ncf.ca/ag136/forkGaiters.htm
and on an EX250
http://web.ncf.ca/ag136/EX250/mediium.html
Offline 2fast
    • ZG Heat Shields
« Reply #4 on: December 04, 2012, 02:35:43 am »
George, are you running a mix of engine oil in the forks?
Brian in Minnesota
Offline KIKKER
  • COG#: 10536
« Reply #5 on: December 04, 2012, 03:06:24 am »
 I am old school all the way.The idea came from a "Survival Rat" concept that I have.I am using the Connie as a platform to build off of. I got them here:http://www.ebay.com/itm/110979533872?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Thanks for the info everybody!
1955 Cushman Eagle
1987 Concours
Offline Centex
    • Central Motorcycle Roadracing Association
  • COG#: 9476
« Reply #6 on: December 04, 2012, 02:09:53 pm »
...... Where'd you get them .....
Many bike shops / internet sellers carry "Daystar" brand fork boots for the MX crowd, lotsa colors and sizes (Google is your friend).  Sorry, I can't find the record of what model I used but the top of the boot/gaiter was a perfect snug fit on the Connie fork, just use a zip-tie to hold 'em up and they've not moved.  I trimmed 'em to length at the bottom and stole George's 'milk carton washer' idea, but since I had the KB brace which is tapped for a fork shield I used those screws/holes to hold the 'washer'/boot down at the bottom.    HTH
Alan in Central Texas
2004 Pearl Black Connie
2001 Ducati M750
« Reply #7 on: December 04, 2012, 02:14:46 pm »
I used the bellows from a set of voyager XII rear shocks. steve
« Reply #8 on: December 05, 2012, 07:08:00 pm »
Yes, a mix of 10W and 20W to approximate 15W. The factory manual recommends SAE10W20. As the second number is applicable at engine temperatures, only the first number is significant at fork temperatures.
