Author Topic: Driving light mount  (Read 11689 times)
Offline Redbarron
  • COG#: 10045
Driving light mount
« on: May 01, 2013, 09:27:45 pm »
Hello everyone:
Does anyone have a photo or photos of the bracket for their driving lamps?
Looks like a bar or tube that runs under the nose of the fairing then the lights mount on the ends.
Just purchased a set PIAA 5370's but I need to figure out how the mounting system is designed.
Thank You All I will post detailed picks during the surgery.
Offline virtualdev
  • Ride.all.year.
  • car broken, ride all winter
    • The Borked Universe
Re: Driving light mount
« Reply #1 on: May 02, 2013, 03:21:02 am »
You mean like a Buck Sport Touring light bar?
Source: http://bucksporttouring.com/lights.html
Offline John_Atkinson
  • COG#: 5921
« Reply #2 on: May 02, 2013, 03:21:03 pm »
I had my brackets custom made as I was running PIAA 910 lamos and they are rather large. They'd likely be overkill for most anything else.
I believe Snarf also makes fairing-mount brackets that look like they would handle many of the smaller lights available these days.
John Atkinson
Windsor, ON
CANADA
COG #5921
Offline Redbarron
  • COG#: 10045
« Reply #3 on: May 02, 2013, 09:51:21 pm »
Thank You Guys, but I am to cheap to spend a $100.00 on something I could fab up from $20.00 worth of hardware.
Hence a photo of the mounting itself, I will be back in the shop Saturday to install my PIAA 530 lamps and do some repairs.
I will post pictures of the project for future reference.
Thank You
Offline virtualdev
  • Ride.all.year.
« Reply #4 on: May 02, 2013, 10:02:06 pm »
If I recall correctly, Larry uses the fairing mount up and behind the headlight with brackets that run down to the crossbar.  I have never seen one in person however.
Offline MotoCommuter
  • Kurt Brown - SE AAD GA
  • If it is not fun, why do it?
  • COG#: 7115
« Reply #5 on: May 03, 2013, 01:12:40 pm »
Don't know how big the PIAAs are but my Denali D1s are mounting on the lower forks where the brake line bracket guide is. Basically remove the guide and bolt in the bracket. Mounting them there allows the light to turn with the front wheel while allowing the main head lamp to project forward.
The Denali's are small LEDs but project a lot of light and so far I have not had any issues with their mounting location.
Kurt
COG ST Track Day [FL]: Feb 7-9
Return To Hohenwald Social [TN]: Apr 3-5
Horseshoe Mtn. Rendezvous [AR]: Apr 23-26
Bun Cooler [ID]: May 15-17
2015 Goldwing ABS & 2014 FJR ES (Holland Custom)
Offline Bruiser
  • Bruiser
« Reply #6 on: May 06, 2013, 06:04:09 am »
Baron, on my old C10, I mounted my lights on a bar I made, using the 2 screws that hold the fairing to the radiator.  I took a 7/8th inch stock of square aluminum tubing I found at Home Depot.  I then measured the distance between those 2 screws I mentioned. It was something like 11 1/2", and I cut those ends at a 45 degree, to form fit the fairing.  I cut the tubing long enough to incorporate these 2 screws, but stay between the fairing edges.  I then took a longer length of tubing, and laid it right across the 1st piece of tubing, so it overhung on each side of the fairing by about 5 inches each, depending on how large your lights are.  I then drilled holes through both pieces of tubing, and ran longer screws to run into the holes, into the mounting holes at the radiator. You should now have your mounting bars for your lights, just run the wiring through the tubing, then up through the fairing to where you want your switch. I then painted the tubing black, and radiused the outer tips under the lights, so they wouldn't scratch anything I encountered, like my bare leg. I think the whole thing cost about $6
Bruiser
2012 Kawasaki C14
93 Kawasaki C10
1982 Honda CX500 Turbo
1980 Kawasaki KZ1000ST
1978 Honda CB750F
1976 Kawasaki KZ400
1976 Honda 750K
1973 Honda CB500K
1973 Honda SL175
1972 Honda SL125
Offline Mr Orange
  • COG#: 6601
« Reply #7 on: June 07, 2013, 10:47:45 am »
Thank You
How about those photos of the install of the new lights?
Offline docdan
  • COG#: 8850
« Reply #8 on: September 18, 2013, 12:27:11 pm »
I'm still looking for a good mount for my led's.  I don't know weather to mount them to the forks or the fairing now.
-Dan
2003 Concours
Offline Mr Orange
  • COG#: 6601
« Reply #9 on: September 18, 2013, 05:05:18 pm »
I should have my new lights mounted by the end of the weekend with the mounts pictured below. I'll let you know how it goes. I'll be documenting the install with plenty of photos.
Offline docdan
  • COG#: 8850
« Reply #10 on: September 18, 2013, 10:54:20 pm »
Sounds great, let us know how it turns out.  I'd be very interested!  :great:
-Dan
2003 Concours
Offline secarob
  • COG#: 11143
« Reply #11 on: September 19, 2013, 12:10:25 am »
Mr Orange,  where exactly are you mounting those?  Fork tubes??
  • Stayin' for the people....
« Reply #12 on: September 19, 2013, 12:14:00 am »
Alright... I'll do it....
 :TPIWWP:
Offline Mr Orange
  • COG#: 6601
« Reply #13 on: September 19, 2013, 12:15:41 am »
Yes, lower fork tubes.
Offline Mr Orange
  • COG#: 6601
« Reply #14 on: September 19, 2013, 12:20:47 am »
 :TPIWWP:
Ok McFly, I feel like I need to jump in here. First I already posted some photos and I said I'm doing the install this weekend. So right now it pretty difficult to post photos of something that hasn't occurred yet.  :))
« Reply #15 on: September 19, 2013, 12:25:11 am »
 :TPIWWP:
You certainly get a pass Mr. Orange...  I look forward to your install thread, as my Connie may one
day have aux lights.....   :beerchug:
To date, I like the faring mounted light brackets best. :great:  Clean, simple, practical.... no longer being made  :'(
« Reply #16 on: September 19, 2013, 12:27:07 am »
From Elvin Rivera's massive album collection:Landing lights photo - Elvin Rivera photos at pbase.com
Offline Mr Orange
  • COG#: 6601
« Reply #17 on: September 19, 2013, 12:48:25 am »
 :TPIWWP:
I have my driving lights (PIAA 910s) mounted high on the fairing. Are these the mounts you are talking about? I know there used to be one that mounted in front of the oil cooler. Is that the one you are referring too? The bar on the blue bike is still available.
« Reply #18 on: September 19, 2013, 01:14:08 am »
I can't find a picture of the ACTUAL brackets, but in my search, I did find this:
(Thanks for the pic MOB!!)
and the way to make 'em...  I'm thinkin' I may give it shot down the road.
I like the location of these on the motorcycle... I guess it's visual aesthetics....
Offline Larry_Buck_FL
    • Buck Sport Touring
  • COG#: 3451
« Reply #19 on: September 19, 2013, 01:12:42 pm »
The lights on Elvin's bike are Hella FF-200's mounted on my mount. Some of the finest driving lights ever. Unfortunately, Hella no longer makes them. Next best from Hella are the FF-50's. They are reasonable priced, but you will have to make up your own wiring from the materials furnished by Hella. The switch is not suitable for our use because it is not weather proof. You will need a "bug switch" for this.
Some FF-200's can still be found, Google around for them. If you find them (driving version - not fog) get them. You won't be sorry.
Offline virtualdev
  • Ride.all.year.
« Reply #20 on: September 19, 2013, 03:14:42 pm »
McFly,
I'm assuming you are talking about these?
I'll see if I can take some close ups of them.  These are the ones Snarf was making from the Guy Young (?) design using the angle iron you showed above from the MOB post :)
Offline virtualdev
  • Ride.all.year.
« Reply #21 on: September 19, 2013, 03:46:58 pm »
Okay, you convinced me, I went outside and took a pic of my bike (luckily I rode into work today)...
Offline docdan
  • COG#: 8850
« Reply #22 on: September 19, 2013, 05:21:55 pm »
I'm looking for these exact ones as well.   Who else makes these on the forum??  (I've contacted Snarf many times with no response yet.)
-Dan
2003 Concours
« Reply #23 on: September 19, 2013, 06:44:28 pm »
McFly,
Yes, thank you virtualdev.  Those are they....  Marty likey  :)
Offline virtualdev
  • Ride.all.year.
« Reply #24 on: September 19, 2013, 06:56:40 pm »
As far as I'm aware, no one else makes them.  The plans from Guy to make them out of angle iron used to be on the web somewhere, and that's how Snarf got the original design.  I believe I got one of the very last sets Snarf made about a year ago.  He's had a lot of long work days and family issues, as well as a crash last year that have kept him unavailable to continue his machining hobby.
Perhaps if we can find the design plans somewhere again we all can start making them out of angle iron.  Or just use the pic here as a template idea (credit to MOB):
Rev Ryder has this concept as well, to bend an L bracket and use in a similar manner: http://forum.cog-online.org/index.php/topic,26814.msg272166.html#msg272166
