Baron, on my old C10, I mounted my lights on a bar I made, using the 2 screws that hold the fairing to the radiator. I took a 7/8th inch stock of square aluminum tubing I found at Home Depot. I then measured the distance between those 2 screws I mentioned. It was something like 11 1/2", and I cut those ends at a 45 degree, to form fit the fairing. I cut the tubing long enough to incorporate these 2 screws, but stay between the fairing edges. I then took a longer length of tubing, and laid it right across the 1st piece of tubing, so it overhung on each side of the fairing by about 5 inches each, depending on how large your lights are. I then drilled holes through both pieces of tubing, and ran longer screws to run into the holes, into the mounting holes at the radiator. You should now have your mounting bars for your lights, just run the wiring through the tubing, then up through the fairing to where you want your switch. I then painted the tubing black, and radiused the outer tips under the lights, so they wouldn't scratch anything I encountered, like my bare leg. I think the whole thing cost about $6
