Author Topic: Electric Connection Recommendation Requested  (Read 1654 times)
Offline Dave Scott
  • COG#: 8603
« on: October 02, 2015, 04:32:21 pm »
I got some grip heaters from Murph's and it's time to get them put on.  I'd like to have them switched through the key so I don't have to worry about forgetting to turn them off.  does anyone have any particular suggestions as to where it could be connected?  Is it even a good idea to splice it in someplace, or should I run a separate line to the battery due to the draw?
any ideas appreciated!   :great:
Offline Outback Jon
  • COG#: 9506
Re: Electric Connection Recommendation Requested
« Reply #1 on: October 02, 2015, 06:11:16 pm »
Separate line to the battery.  Use a relay that is triggered by something else when the key is on to energize the circuit for the grip heaters.  Running lights make a good relay trigger.
Offline SteveJ.
  • COG#: 5603
« Reply #2 on: October 02, 2015, 10:29:03 pm »
Dave, do consider an aux fuse box for future farkles.
You may wanna hook up the relay trigger to the wire that kicks in the headlight, I believe it is the blue one coming out of the Jbox. That way the loads from the aux box do not pull on the battery until it's running. Use at least a 30 amp relay, 40 would be better. I have headlights, aux lights, extra horns, grip heat, trailer lighting, and clothing outlet fed from the aux box. It lightens the load on the Jbox in my case.
HTH.
Tick Tock, baby (Ironbuttal)
Offline ron203
  • COG#: 9847
« Reply #3 on: October 02, 2015, 11:37:25 pm »
I used Murph's fuse box. It was a little pricey but included the relay AND instructions. If I can do it right the first times..well almost anybody can.  ;D
2014 C-14
2008 Goldwing
« Reply #4 on: October 04, 2015, 08:15:03 pm »
 If you're only doing one add on like grip heaters, this is a good way to go just using a relay. But I would prefer to trigger/switch the relay off  of headlight circuit to help protect the battery upon start up.
 But if going with multiple accessories. Then definitely go with an auxiliary fuse box.
Offline Dave Scott
  • COG#: 8603
« Reply #5 on: October 05, 2015, 12:05:08 pm »
good idea guys.  I think it's time for the aux block with a relay.  I can use it for my gps connection, charger for the video camera and now the heated grips.  Off to Murphs I go.....again!   :great:
Offline Ranger Jim
  • COG#: 6720
« Reply #6 on: October 05, 2015, 12:58:23 pm »
+1 for Murph's aux fuse box. EZ install and works great! :great:
JIM CULP
