Author Topic: Electronic Cruise Control  (Read 4210 times)
Offline Wess
  • COG#: 8010
« on: August 14, 2009, 04:53:00 pm »
Does anyone know if there is one on the market for the Conk?  Respectfully Yours!  Wess Heavner   2009 Hard Luck Award Winner!  COG #8010 CDA #0239
Respectfully Yours!
Wess Heavner
Independence, MO
millerized
  • Guest
« Reply #1 on: August 14, 2009, 07:53:00 pm »
Ya mean like this:  http://www.murphskits.com/catalog/product_info.php?products_id=69    http://millerized.com/pegs  I'll be in the garage  COG 6425, CDA 111 a through g
Offline Larry_Buck_FL
    • Buck Sport Touring
  • COG#: 3451
« Reply #2 on: August 14, 2009, 08:26:00 pm »
Wess,    I've had the Audiovox for about 10 years now. Good unit.    There is another one the C-14 guys are using call Rostra. It does not need a vacuum source to control the speed, but I'm not sure the C-10 can electrically provide the info it needs. Perhaps someone else can shed some light on the Rostra for the C-10.  Larry Buck  COG 3451,SE-AD (Retired)Concourier C-10 Tech Editor ROK,MTF,IBA,MSF-RC  Buck Sport Touring-"Ride Far" www.bucksporttouring.com
« Reply #3 on: August 16, 2009, 07:18:00 pm »
the Rostra is not suited for the C10 as it relies on electronic pulse from the speedo sending unit to maintain set speed.  The Audivox is the best route on the C10, as old Conni is an analog speedo drive, and you are just using a basic engine RPM control to set rolling speed.(sensed from engine coil).
« Last Edit: August 16, 2009, 07:22:00 pm by MAN OF BLUES »
Offline Bogie 1
  • COG#: 6224
« Reply #4 on: September 08, 2009, 08:47:00 pm »
apparently murphs is not able to get any audio vox from the supplier even since July.  I checked the audio site and the crusie control isn't on it.  Now, as to my need regarding audio vox.    I need two lengths of beaded chain and one bead chain coupler.      Help??    Anyone??    Bob
Offline Charlie_Gary_AAD
  • COG#: 8048
« Reply #5 on: September 09, 2009, 06:42:00 am »
     Lamp section of the hardware store?  Just a guess.
Later,
Charlie - NWAAD
COG# 8048
AMA# 603377
Re-defining the phrase "Rides like a grandpa"
Offline Doug_Wood_IL
« Reply #6 on: September 16, 2009, 10:17:00 am »
Regarding availability of the CCS-100 kit.....    I did a Google search and found a seller on Amazon.com with a couple of the kits in stock. I bought the last one he had, and am looking forward to a few rainy days when I can make some time to install it.     What have those of you who have the CCS-100 done for a vac tank? I hate to spend $30 or $40 for such a small simple item. I'm thinking a short length of plastic pipe capped, and tapped for 2 vac fittings?    TIA for any ideas    Doug
Doug Wood  DeSoto,IL    CDA#0314  AMA#1090587
Offline Victor Salisbury
  • COG#: 3673
« Reply #7 on: September 16, 2009, 02:49:00 pm »
That's exactly what I did. A 1" dia (?) by 8" long pvc pipe capped.     I'm not sure if it was necessary for my bike, but prior to putting the canister on, I was tapping vacumn from cyl 1, 3 and 4. I left #2 dedicated to the petcock. Before and after canister performance was the same for my bike on hills and overpasses.   Do you have the vacumn check valve, that is another necessity.    I've installed quite a few of these, if you need anymore help, shout away.
« Last Edit: September 16, 2009, 02:49:00 pm by Vic Salisbury »
Vic Salisbury
COG #3673
'97 Connie "The Grinch"
Sarasota, FL
www.cog-online.org
« Reply #8 on: September 16, 2009, 11:19:00 pm »
Will do Vic! Thank you sir!    Doug
« Reply #9 on: September 23, 2009, 02:00:00 pm »
Any suggestions, part numbers or suppliers for the vacuum check valve anyone?     TIA,  Doug
  • COG#: 3673
« Reply #10 on: September 23, 2009, 03:44:00 pm »
I have a couple of part number suggestions: Universal Vacumn Check Valve:  NAPA part # 730-1347 - the last one I got from NAPA was a carded item hanging on the wall on the sales floor.    Other Auto stores (Advance, Autozone) that have the HELP! line of products, it's the aisle where you find the replacement window cranks, bleed valves, trim fasteners and other assorted stuff, that part number is 47149.    Now on one of these check valves one nipple is a smaller diameter than the vacumn hose. I used some heat shrink to build up the nibble to a larger diameter so the hose would stay on.   Did you build a vacumn canister already? How did that go?
Vic Salisbury
COG #3673
Sarasota, FL
www.cog-online.org
« Reply #11 on: September 23, 2009, 09:56:00 pm »
Good info as I'm on the phone with my Napa guy several times a day, so the Napa number will work perfect. No, I haven't built the vac tank yet. Did you use plastic or brass nipples on the tank?    Thanks,  Doug
  • COG#: 3673
« Reply #12 on: September 23, 2009, 11:13:00 pm »
Cool deal, just make sure they don't think you are talking of a check valve for a brake booster, little too big  :)    For the nipples, I actually had a small piece of copper tubing the right diameter. Don't have a clue where I got it from though. Might have been scrap left over from running an aftermarket oil pressure gauge in a car years ago?  Drilled the hole so the tube pressed fit in, then used some two part epoxy to seal.
Vic Salisbury
COG #3673
Sarasota, FL
www.cog-online.org
Offline Zorlac
  • COG#: 6962
« Reply #13 on: September 24, 2009, 07:53:00 am »
I used a blister pack replacement vacuum check valve for a car power brake booster from an auto parts store, unfortunately the hose ports are very large.    Maybe one of these?  http://www.usplastic.com/catalog/product.asp?catalog_name=USPlastic&category_name=45&product_id=20411
COG #6962
« Reply #14 on: September 24, 2009, 09:42:00 am »
thanks guys!    Doug
Offline Limey
  • COG#: 8902
« Reply #15 on: September 24, 2009, 10:58:00 am »
McMaster-Carr also has a selection of check valves - including small in-line versions.    I was going to build my own vacuum tank too, but by the time I added up all the parts, and made the trips (or paid the shipping), it was cheaper to buy the Audiovox tank from Murph!
Eric in South Lyon, MI  1978 KZ650  2000 ZG1000
Offline MaD MiKe
  • COG#: 8837
« Reply #16 on: September 24, 2009, 12:02:00 pm »
If you have tip over bars on the bike you can use one of those for a vacuum canister.  I did this on my V-Strom.     If room on the bike was a question and I had the handlebar mod on the C10 I might even use the handlebars as a vacuum canister. Plug the ends far enough to get the bar end weights back in, plug some holes  and a couple of nipples and you're set..  Clean look?  I don't know but I definitely would consider it.
2006 ZG1000 Concours,  2007 650 V-Strom,     1979 KZ1000ST (a work in slow progress)
Offline tom_epp_NC
« Reply #17 on: October 05, 2009, 01:06:00 pm »
hey wess, idk if your still lookin but i saw one on ebay. it's not that rosetta or what ever it's called but it is electronic with no vac can. i THINK it will work on the c-10. it looks like it still uses the coil signal. i think it was like $189.00 let me know if your still lookin and i'll see if i can find the ad i was lookin at.    ok the seller is audiovideo4me on ebay. the item number for the auction is 120429396374.
« Last Edit: October 05, 2009, 04:42:00 pm by tom_epp_NC »
« Reply #18 on: October 05, 2009, 02:57:00 pm »
My understanding is rosetta or whatever needs a signal that the C10 can not supply to work.  Photos[/url]
