Concours Discussion (C10 / ZG1000 / 1000GTR) => Accessories C10 => Topic started by: connie1079 on October 13, 2018, 05:18:40 pm
Title: Front and Rear Turn Signals
Post by: connie1079 on October 13, 2018, 05:18:40 pm
I would like to change my blinker bulbs to l.e.d. Can I simply get the led version of push n turn bulbs and all will work fine? Or do I have to get upgraded relay for the led bulbs inplace of the stock one?  How hard is it to get to the front amber bulbs? Thanks for your info folks.
Title: Re: Front and Rear Turn Signals
Post by: who me? on October 14, 2018, 12:21:12 am
The bulbs themselves are plug and play I needed a relay(relay is plug and play also)
https://www.superbrightleds.com/moreinfo/flashers-load-resistors/cf13jl-02-led-bulb-electronic-flasher/783/837/ (https://www.superbrightleds.com/moreinfo/flashers-load-resistors/cf13jl-02-led-bulb-electronic-flasher/783/837/)
Pull your inner side panels off You should be able to get to the front lamps
Post by: connie1079 on October 14, 2018, 01:00:52 am
Thank you for the info.
Post by: JPD on October 14, 2018, 12:44:19 pm
Here is a link to a source for both the tail/ brake and front turn/running lights. The difference between low and high is impressive.
This is for West Coast Classic Cougar. They have parts for old Cougars. They are expensive but I want to be seen. I tried cheep led tail/brake off ebay and didn't like them. The tail lights are plug and play but you will need to get the flasher upgrade for led turn lights.
I got this info from another post on updating all of your light to led on this forum.
Http://www2.cougarpartscatalog.com/plasma2.html (http://Http://www2.cougarpartscatalog.com/plasma2.html)
Tail brake
Plasmayellow.html
Front turn running
