Author Topic: Front and Rear Turn Signals  (Read 300 times)
Offline connie1079
« on: October 13, 2018, 05:18:40 pm »
I would like to change my blinker bulbs to l.e.d. Can I simply get the led version of push n turn bulbs and all will work fine? Or do I have to get upgraded relay for the led bulbs inplace of the stock one?  How hard is it to get to the front amber bulbs? Thanks for your info folks.
Offline who me?
  • COG#: 11932
Re: Front and Rear Turn Signals
« Reply #1 on: October 14, 2018, 12:21:12 am »
The bulbs themselves are plug and play I needed a relay(relay is plug and play also)
https://www.superbrightleds.com/moreinfo/flashers-load-resistors/cf13jl-02-led-bulb-electronic-flasher/783/837/
Pull your inner side panels off You should be able to get to the front lamps
95 C10 The Mule
02 C10 parts are parts
Offline connie1079
« Reply #2 on: October 14, 2018, 01:00:52 am »
Thank you for the info.
Offline JPD
  • COG#: 12064
« Reply #3 on: October 14, 2018, 12:44:19 pm »
Here is a link to a source for both the tail/ brake and front turn/running lights. The difference between low and high is impressive.
This is for West Coast Classic Cougar. They have parts for old Cougars. They are expensive but I want to be seen. I tried cheep led tail/brake off ebay and didn't like them. The tail lights are plug and play but you will need to get the flasher upgrade for led turn lights.
I got this info from another post on updating all of your light to led on this forum.
Http://www2.cougarpartscatalog.com/plasma2.html
Tail brake
Plasmayellow.html
Front turn running
