Author Topic: Gas Cap Mount  (Read 1724 times)
Offline Piston720
  • COG#: 10213
Gas Cap Mount
« on: August 25, 2015, 02:57:53 pm »
Does some have the part number for the mount that fastens to the gas cap.
The one I fine is part #ACM-HB462, it states that it fits all Hondas and BMW's.
Sold through KAPSCOMOTO on Amazon.ca
Offline worncog
  • COG#: 9584
Re: Gas Cap Mount
« Reply #1 on: August 25, 2015, 03:29:45 pm »
Are you speaking of the mount to add a Ram mount for cell phone or GPS?
Like this: http://www.amazon.com/Adjustable-Mount-Motorcycles-Camera-Player/dp/B002GTK89Q
RWTW, COBDR, SM 500, BVF...
Offline Piston720
  • COG#: 10213
Re: Gas Cap Mount
« Reply #2 on: August 26, 2015, 10:55:37 am »
Just ordered one.
Offline Piston720
  • COG#: 10213
Re: Gas Cap Mount
« Reply #3 on: September 08, 2015, 03:11:13 pm »
Just one more question.
It is all mounted but I would like to bend the mounting face towards me about 30*.
Has anyone bend this metal/Aluminum?
It seems fairly rigid and I was leery on applying to much force.
I would like to bend it just above the bottom slot where it has a horizontal cut already 1/2 way through.
Is it possible or will the metal fatigue and break?
Offline worncog
  • COG#: 9584
Re: Gas Cap Mount
« Reply #4 on: September 08, 2015, 04:20:57 pm »
If you bend it, the powdercoat will crack.
Instead of bending, why not substitute a single nut and bolt with washer arrangement for the thumbscrews? A nylon locknut would work well here. This will allow you to tilt up the bracket to an angle of your choice.
Offline Piston720
  • COG#: 10213
Re: Gas Cap Mount
« Reply #5 on: September 08, 2015, 05:53:32 pm »
That is so simple, it hurts that I did not think of it.
I could not get past trying to incorporate the rubber washers, on the thumbscrews, for any vibration issues.
Thank you.
