Author Topic: Got my pegs in yesterday, Thanks  (Read 1210 times)
Offline Rob
« on: June 16, 2009, 08:33:00 am »
Jim,    Pegs came in the mail yesterday, and wow. The all black powder coating looks great. The craftsmanship is exceptional and the installation video will be very helpful. I'm shooting for this weekend to get them installed. Thanks again for providing a great product at a good price.      2004 Connie
millerized
  • Guest
« Reply #1 on: June 16, 2009, 09:05:00 am »
[blushes] Thanks. [/blushes]    Black? I thought I sent you pink :p    If you need a hand installing them, give me a shout. If you're still happy with them, tell your friends.  If you're not, tell me.  Thanks again!  http://millerized.com/pegs  COG 6425, CDA 111 a through g
Offline Rob
« Reply #2 on: June 16, 2009, 12:07:00 pm »
Pink? Very funny. I will let you know if I run into trouble installing them. CD looks pretty straight forward with basic tools. Is the engine threaded at the motor mounts or is the other side of the mount threaded? Any torque requirements?   2004 Connie
millerized
  • Guest
« Reply #3 on: June 16, 2009, 02:31:00 pm »
IIRC, but I'll have to check when I get home to make sure: There's a bracket that is threaded on the inside of the motor mount. Motor is just a tube for the bolt to slide through. Loosen one side at a time to prevent any movement.    The torque is 40ftlbs. I'm not sure where I got that spec for that, but I think it was either the Clymer or Kawa manual. Use German torque if in doubt. (Gutentight)    Yes, it's a simple procedure.  The only "hard" part is cutting the hole in the heat shields. While it's not hard cutting (relatively soft plastic) getting the spacing perfect seems to be.  Don't worry about breaking, hacking, butchering or even bodging the heat shields, they have connection points above and below the cut/crack/crevice/canyon you put in.  They'll stay put even if you installed the grand canyon between the pieces.  They're unseen, way under the fairing lowers when done. If I could find a copy of the install for the Rivco tip-over bars bracket, it's pretty much the same cut-out.    I have faith in you.  There are many who have gone before, and I still only have the original openings I was issued with, so it can't be all that hard.    http://millerized.com/pegs  COG 6425, CDA 111 a through g
« Last Edit: June 16, 2009, 05:31:00 pm by millerized »
Offline HOOGIE001
  • COG#: 5737
« Reply #4 on: June 16, 2009, 09:25:00 pm »
Rob,    I had bought a set from Jim about (I forget how many years ago). Every so often I would get a question on where I got them - but had to say you can't get them any more.  I was happy to see that Jim has decided to 'start-up' again.  I had them on my 2000 and transfered them to my 2006 when I got it.  They are my 'long-distance' friends (left and right).  Easy to install, and real leg savers for my 6'5" legs - well, my legs are long.  You can't go wrong.  You'll see them on a some pics if you click on the link below.    John Hoogewerf  COG5737  Lansing, Illinois
« Last Edit: June 17, 2009, 12:27:00 am by Baldeagle001 »
Offline Rob
« Reply #5 on: June 17, 2009, 01:17:00 pm »
What do you think about this scenerio. Just in case of total distruction of the heat sheild, wrap the pipes with something like heat tape. This is a worst case scenerio of course. I don't have a zip tool but I do have a dremel that should do the trick.  2004 Connie
