Author Topic: gps mount  (Read 1580 times)
Offline Steve
  • COG#: 12718
gps mount
« on: December 28, 2017, 01:48:24 pm »
Greetings. I have a 93 ZG1000 purchased new and it's been upgraded with Performance Machine 320mm rotors and their calipers, powder coated wheels and aftermarket exhaust etc. As I have other interests in the exotic car world the bike was unused for a number of years. I brought it out of hibernation earlier this year and did some 1200 miles or so. I was a long time past member of COG and just rejoined yesterday and happy to be back.
 My inquiry is... Is there an aftermarket mount available for a Garmin/TomTom gps for this bike and if so where can I purchase one. When I bought this bike this stuff was in its infancy or didn't exist. Been riding Kawasaki's since 1969.
Thanks, Steve
Offline GeorgeRYoung
Re: gps mount
« Reply #1 on: December 28, 2017, 02:17:42 pm »
Offline ron203
  • COG#: 9847
Re: gps mount
« Reply #2 on: December 28, 2017, 02:24:10 pm »
Go to"rammount.com" then search for "motorcycle" using their site search box. Then search on Amazon or Google to find resellers.
2014 C-14
2008 Goldwing
Offline Steve
  • COG#: 12718
Re: gps mount
« Reply #3 on: December 28, 2017, 02:42:33 pm »
Thanks guys. As it's a 93 I prefer to not lose the l/s pocket if possible and maintain as original as possible. As my shop has some fabrication facilities I may try to make one up or modify the existing one that came with the unit. I believe there are aftermarket mounts available at Best Buy etc and I was thinking of mounting it to the back side of the instrument panel (as you are looking at it) as that would not block gage vision and is behind the slip stream. Obviously I want the least amount of vibration when mounted.
I will also look at the mounts suggested...
Thanks.
Offline oldsmoboat
  • 2004 C10
Re: gps mount
« Reply #4 on: December 28, 2017, 05:32:35 pm »
I have a Ram mount installed on Larry Buck's shelf.
Online who me?
  • COG#: 11932
Re: gps mount
« Reply #5 on: December 28, 2017, 05:41:43 pm »
+1
Quick easy no major modifications to the bike
95 C10 The Mule
02 C10 parts are parts
Offline cra-z1000
  • Keeping it upright..
  • COG#: 9790
Re: gps mount
« Reply #6 on: December 28, 2017, 07:17:30 pm »
Larry Bucks shelf is no longer available though  :(.
1987 C 10
80 Kawasaki KZ 1000 MK 2
74 Honda 750 four ss
73 Suzuki 550 triple
72 Honda 550 four
Offline Sport Rider
  • COG#: 8603
Re: gps mount
« Reply #7 on: December 28, 2017, 07:24:56 pm »
a ram ball mount will fit into the brake and clutch mounts where mirrors would otherwise screw in.  another option which is a little more intrusive is to remove the cover under the dash which is just above the gauges.  there are two screws that hold it on.  once removed, I mounted a flush mount ram mount to the top of the dash with a couple small bolts.  PM me if you'd like pics.
Online who me?
  • COG#: 11932
Re: gps mount
« Reply #8 on: December 28, 2017, 07:55:24 pm »
He had me on a waiting list until he got enough orders to make a run
That was about two years ago
No longer on the website but if enough wanted one you might could talk him into another run
95 C10 The Mule
Offline Jorge
  • COG#: 9297
Re: gps mount
« Reply #9 on: December 28, 2017, 10:55:09 pm »
There are two more options...
1- Ram makes a mount that uses the same screws as the brake lever, or the clutch lever. The mount goes over the clamp portion of the lever housing and is fairly secure. I have one of these on my C14, but I'm pretty sure it would work on the C10 also. Here's a link to this mount:
https://www.ebay.com/itm/RAM-B-309-1U-Ram-Mounts-Cycle-Brake-Clutch-Reservoir-Base-w-1-Ball/121723713074?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D1%26asc%3D20160908110712%26meid%3D7630b9486e9446f6bada9c63b0a02b56%26pid%3D100677%26rk%3D6%26rkt%3D29%26sd%3D201948147810&_trksid=p2385738.c100677.m4598
2- Make a angle bracket, and mount the GPS on top of the Dashboard. This requires drilling 4 holes into the dashboard "hood", but it is an unbeatable location for the GPS. It's below your line of sight, but not that far, so it's easy to look at it with a slight downward glance. It also mounts it further away from your eyes, so the re-focus time for your eyes is reduced. The bracket is pretty simple, and vibrations are not bad. I had a Street pilot 9826 mounted there, and it lasted years. I attached the two best photos I could find of the bracket.
Re: gps mount
« Reply #10 on: December 29, 2017, 02:18:57 am »
. . As it's a 93 I prefer to not lose the l/s pocket if possible and maintain as original as possible.  . . ,
It's above the LHS pocket and it sticks on with 3M Molding Tape.
Offline Jorge
  • COG#: 9297
Re: gps mount
« Reply #11 on: December 29, 2017, 10:04:32 am »
George,
I'm not sure if I'm that special, but I had a little trouble with 3M trim tape sticking well. I had my heated grips (Oxford Heaterz) installed in that position, and had to re-stick them at least ones, maybe twice, over the years. Since it was a relatively light module, and had a healthy cable coming out of it, it wasn't a major issue and when it came off it just sort of hing there, but I would be afraid of mounting a GPS.
Could be that, even though I cleaned the are prior to attaching, I didn't clean it properly, but...
Jorge (spelled the efficient way - LOL)
Re: gps mount
« Reply #12 on: December 29, 2017, 01:03:06 pm »
Well, I've used it for the GPS mount and the FendaExtenda thingie, fine results so far. Still have half a roll to go.
Offline Jorge
  • COG#: 9297
Re: gps mount
« Reply #13 on: December 29, 2017, 01:33:46 pm »
 :great:
Offline Sport Rider
  • COG#: 8603
Re: gps mount
« Reply #14 on: December 29, 2017, 01:38:47 pm »
George,
why isn't it spelled Jorje?   :D
PS...don't trust anyone who rides an 05 C10.   :-X
Online JPD
  • COG#: 12064
Re: gps mount
« Reply #15 on: December 29, 2017, 02:14:03 pm »
I use the RAM mount ball that screws into the mirror mount holes. One on each side. You can find RAM parts for anything.(go to their web site) I recommend that you use the aluminum arms not the composite. I over tightened a short composite arm and it cracked. RAM did replacement for free.
Offline Victor Salisbury
  • COG#: 3673
Re: gps mount
« Reply #16 on: December 29, 2017, 02:49:49 pm »
+1  that's what I did, keeps the gps basically in line of sight. I tried the clutch and brake reservoir mounts years ago but the vibes seeped through and would cause issues with the gps even thought I tried to rubber 'isolate' what I could.
Vic Salisbury
COG #3673
'97 Connie "The Grinch"
Sarasota, FL
www.cog-online.org
Offline Steve
  • COG#: 12718
Re: gps mount
« Reply #17 on: December 29, 2017, 03:13:32 pm »
Gentlemen, Thank you all for your input. I brought the gps unit in the shop today to trial fit it on the bike. It appears it was as Shakespere would say "much ado about nothing" I guess I over thought this.
 The supplied Tom Tom mounts will function just fine in either the on top of the ip cluster location or just above the l/s storage pocket using their supplied base and suction cup twist lock. I installed a 12 volt accessory outlet years ago so I'm good to go when the glaciers up here melt away... I will purchase the recommended mounts as a back up.
As a side note my original COG membership number was 1573 and my AMA number is 770876 Lifetime... if that help the membership director.
Again, Thank you all for your input!!!! :great:
Steve
Offline Jorge
  • COG#: 9297
Re: gps mount
« Reply #18 on: December 31, 2017, 06:02:08 pm »
Trust even less one who used to have a 05 C10 until he... used it up   :'(
Thanks Dave!   I'm sure i'll be able to return the compliment  :P
Steve,
Glad you figured this one out. It took me a little longer. My 1st try was a car GPS mounted to the plastic cover under the ignition switch. It worked OK, but vibrations on that spot ended up wearing the contacts so it would re-boot as I was driving.  :-[
Welcome back to the monkey house!
Offline Steve
  • COG#: 12718
Re: gps mount
« Reply #19 on: January 02, 2018, 02:56:21 pm »
Monkey House??? Ok I'll go with that...
Actually as I do a lot of fabrication albeit some of it minor to my clients cars and this was fairly easy once I just got to it. As a back up I will add a tether to the unit in case of a mount failure. I noticed the ip cluster will vibrate a little bit more than the l/s  fairing inner trim so that's where I'll probably mount it.
Too bad I could not get my old COG number back, oh well, progress I suppose.
Offline connie1079
Re: gps mount
« Reply #20 on: October 06, 2018, 06:12:16 pm »
I use this on my connie and it holds phones and gps. I got it cheap at walmart. It comes with a sticky adhesive suction pad that has not loose since i first put it on.
