Author Topic: GPS Wiring Question  (Read 1516 times)
Offline captconcours
  • COG#: 6513
GPS Wiring Question
« on: May 27, 2009, 11:36:00 pm »
Hi All, I just recently purchased a Garmin 660 for my 05 Connie and   would like some advise on the best place to connect the unit to the bike.    The cradle comes pre-wired so you can hard wire it to the bike in   addition to have and audio in and out connection.  I don;t expect to use   those since the 660 is bluetooth capable.  The wires for the cradle came   with an in line fuse I just need to figure out where to connect it.  Any and   all assistance is GREATLY appreciated.    :)    TIA,      John Ashton  Ft. Worth, TX  COG 6513  AMA 1078826  05 Concours
John Ashton  Ft. Worth, TX  COG 6513  CDA0326  AMA 1078826  05 Concours
Offline S Smith
  • Northeast Area Director
  • COG#: 3184
GPS Wiring Question
« Reply #1 on: May 28, 2009, 05:30:00 am »
There is an accessory power connections under the left glove box which are hot all the time.   --  Steve Smith, COG #3184  COG Northeast Area Director  (somewhere in south central CT)     If you're not living on the edge, you're taking up too much space.
Offline krumgrinder
  • COG#: 6550
GPS Wiring Question
« Reply #2 on: May 28, 2009, 05:00:00 pm »
Hey John,  I added one of these to the outside of my battery box on the right side, and run wires from all of my accessories directly to it.  If you think you might add other stuff, it's a good, safer way to start.  There's a couple of pics here of my RAM mount and Garmin cradle install for my Quest that might help, but they are not specifically of the wiring.  As Steve says there is a hot lead under the front left instrument shroud that is a bullet type connector receptacle, one of a pair, that are always on- not such a great thing for items that might drain the battery if left on and you walked away from the bike.  Wiring to a fuse box with a relay in series is the best way to go, IMHO.  I ran my wires down along the handlebar to the frame ridge and along under the tank to the underseat area, tieing up w/zip ties along the way.  Steve K.  '02 Concours 'Locomotive Breath'  COG# 6550  AMA# 965469  'No matter where you go, there you are...'
Steve K.
'11 KTM 990 Adventure 'The Ripper'
'02 Concours 'Locomotive Breath' (gone but never forgotten)
Offline Eddie-FL
  • COG#: 7073
GPS Wiring Question
« Reply #3 on: May 28, 2009, 08:37:00 pm »
And don't forget, our good friend Murph has a power panel with the relay built on (in?) to it. I don't have my GPS run to it, but have a bunch of other stuff going there. I ran mine straight to the battery, but you could tie into the accessory leads under the fairing as Steve mentioned. I leave mine powered all the time when on a trip so I don't have to wait for it to initialize each time I start out. Just remember to turn it off for a long layover!    Eddie  Sanford, FL  2005 Concours  1969 Triumph Bonneville  AMA# 686667 COG# 7073 CDA# 0136     http://picasaweb.google.com/Eddie753
Anderson, SC
  • COG#: 6513
GPS Wiring Question
« Reply #4 on: August 30, 2009, 11:30:00 am »
Hi all, thanks for the replies.  I have a follow-up question now that I havae actually gotten around to trying to get the GPS wiring done.  I have decided to connect to the hot connections under the seat, the GPS comes with an inline fuse and by putting it under the seat it will be easy to get to if needed.  Also in thinking about it I like the idea of the unit staying on when the bike is off, say at a gas station so I can continue to listen to tunes while filling up.  If I leave the bike the unit comes with me so I don't anticipate a problem draining the battery.  Here is my question, I understand the there are two connectors under the seat, one is hot the other is ground, both will take two bullet connectors, but which is which?  I think the blue/white wire is the hot one and the yellow/black is ground but would like some comformation before connecting the unit.  I have read this information somewhere I can not remember if it was on the forum of the list server.  Any assistance is greatly apprecieated.  John Ashton  Ft. Worth, TX  COG 6513  AMA 1078826  05 Concours
Offline Victor Salisbury
  • COG#: 3673
GPS Wiring Question
« Reply #5 on: August 31, 2009, 12:23:00 am »
John,    You have it right, blue/white is hot and yellow/black is ground.    Enjoy  HTH
Vic Salisbury
COG #3673
'97 Connie "The Grinch"
Sarasota, FL
www.cog-online.org
