Author Topic: Function of fairing extenders  (Read 4044 times)
Offline Solomookie
  • COG#: 11738
« on: May 21, 2015, 02:08:56 pm »
I bought fairing extenders to help protect from the cold during winter riding and they work great.  Now, as warm weather approaches, I'm ready to remove them.  However, as my brother (a fellow biker) and I were talking last night, he pointed to the large vent hole in the lower fairing and asked, "isn't that where the radiator and engine heat vents?".  I assume yes, and he continued, "Wouldn't it be better to have the extender there to deflect the hot air away from you?".
Hmm.. not sure.  So there are three options.  1) Leave the extenders on  2) Replace them with the stock "wings"  or 3) Take the extenders off and leave the fairing "naked".  Any one have an opinion on the optimal configuration for beating the heat?
'98 Connie x 2, farkle expenditures nearing the GNP of Bolivia; it's a sickness.
Offline Outback Jon
  • COG#: 9506
Re: Function of fairing extenders
« Reply #1 on: May 21, 2015, 02:49:32 pm »
At the very least, take the extenders off.  You'll be much cooler.  I've left the scoops off of mine, mostly because I like how it looks without them.
Offline Stasch
  • COG#: 6830
« Reply #2 on: May 21, 2015, 03:09:06 pm »
I fabricated a pair of adjustable wings similar to Baker Air Wings used on larger touring bikes.
I like having 'on the fly' tunable options.
In Michigan we can see temps from 40F to mid 80's in one day.  Temps also drop quite a bit if you're riding along side one of the Great Lakes.
For reference, I have the largest Cee Bailey shield and also will use Brian's Heat Shields in the hottest part of the year (to keep from baking my shins) and the wind wings really help in both cold and hot conditions
Offline goatmar
  • COG#: 7957
« Reply #3 on: May 21, 2015, 05:03:56 pm »
They help with the rain too, I leave mine on all year.
Offline Red Eagle
« Reply #4 on: May 21, 2015, 06:01:10 pm »
 :great:
I leave mine on all year also. We get the four seasons here in Northern California and it can get hot. But the reason I like them is they "seem" to make the bike more stable in windy conditions or when passing big trucks.
Bob Young   COG #5753 C-10 A-1 CDA#307
Offline ACISROC
  • Coordinator for the" Help A Cogger Out" thread.
  • Red C-10 called Diablo
  • COG#: 11845
« Reply #5 on: May 21, 2015, 08:50:07 pm »
 I flip over the stock wings in the summer and it really helps around the boot area, Took me two years to figure that one out. :-[
There are "Bold Riders" and their are "Old Riders" but their are very few "OLD BOLD RIDERS"
 2003 C-10, C.O.G.Member#11845, A.T.G.A.T.T.
SW Chapter "Bold Riders" Retired Scout 12%er
Offline Jorge
  • COG#: 9297
« Reply #6 on: May 22, 2015, 12:37:32 am »
The extenders punch a much bigger hole in the air. They create a sort of vaccum behind them, and much of the air that fills this vacuum comes from the engine.
I take them off as the wether turns warmer, and put back the scoops in front of my feet.
Jorge
Offline bajakirch
  • CDA #0481 :-(
  • COG#: 10298
« Reply #7 on: May 22, 2015, 02:58:16 am »
We must have gone to the same school, cuz it took me about as long to figure that out too.
Definitely helps with the lower leg area, at least.
If you can't be a shining example, at least you can be a horrible warning.
Offline Outback Jon
  • COG#: 9506
« Reply #8 on: May 22, 2015, 10:25:38 am »
Well, the stock "wings" are supposed to be scoops, if the dealer installed them correctly.  They're supposed to bring cool air into your feet and lower legs.  Switching sides and flipping them over into air deflectors is a "feature" to deflect some air away from your feet in cooler weather.  (I believe there is some debate as to whether this feature was designed intentionally)
Offline ACISROC
  • COG#: 11845
« Reply #9 on: May 22, 2015, 09:14:28 pm »
                         Proaobly same school in Wisconsin, Slinger and Milwaukee LOL :rotflmao:
Offline Slybones
  • COG#: 6953
« Reply #10 on: May 26, 2015, 10:06:29 pm »
Only took 1 - 100+ degree day to figure it out. I now swap in/out in spring/fall.
2003 Concours, 121K
2005 GL1800ABS, 52K
COG #6953, IBA 28004
Offline RodWpg
« Reply #11 on: May 27, 2015, 01:43:24 am »
embrace the heat  :)
Offline PaulP
  • Software Engineer
« Reply #12 on: May 28, 2015, 01:06:55 pm »
I just flipped mine over now that it's getting warmer here in Minnesota. Felt good this morning to get some cool air on the boots without having to position the feet on the very end of the pegs.
Offline diablo6v
« Reply #13 on: June 02, 2015, 12:49:48 am »
Well since you are referring to my old bike. I found that it handled best with out those stupid little black wings that come with the bike. I found they tend to make the bike "dance" more on the freeway.. The cold weather wings that were on there make a huge difference. I got them in August one year and had to try them out..Big mistake it was like a sauna on that thing in traffic..(well Florida in august is a sauna hahahaha) From about May until October i left all the wings off..We have a long a** summer here.. :))
Offline Solomookie
  • COG#: 11738
« Reply #14 on: June 02, 2015, 11:01:57 am »
Actually, I was referring to both bikes.  I have the same set up on "mine".  I pulled the fairing extenders and put the scoops on in the "summer" position.  I haven't noticed any change in handling, but from my first few rides of the new hot season I also can't tell that they are doing anything to help.  I've decided to pull them off since I think the bike looks better without them.
Offline ACISROC
  • COG#: 11845
« Reply #15 on: June 02, 2015, 07:16:35 pm »
                +1^^^^^^
Offline Thud300
« Reply #16 on: June 03, 2015, 02:33:06 pm »
Do the scoops assist air movement through the fairing as well as direct air onto the boots?
1991 Voyager XII "Xaviera"
1989 454 LTD "Merlin"
Offline PaulP
  • Software Engineer
« Reply #17 on: June 03, 2015, 04:16:27 pm »
Not as far as I can tell. I'm not even sure they direct much air onto the boots. I suppose I should test them someday by riding for a while and then taking them off and riding the same route again to see if I can notice a difference. The hotter the ambient temperature, the less effective they will be, I'm guessing.
« Reply #18 on: June 04, 2015, 09:06:17 pm »
+1  Same here
2000 Red C10 1052 kit
