Author Topic: Plug for SISF  (Read 1677 times)
Offline oldsawfiler
  • COG#: 8062
Plug for SISF
« on: July 08, 2010, 12:59:00 pm »
Sent Steve a "spare" set of carbs for him to rebuild with his jet kit early last week.  Got them back Tues.  That's from the Seattle area to Florida and back!  Lots of personal contact including E-Mails and Phone calls to confirm info.    Will install as soon as the weather permits.  It's to Damn hot to work out side right now.  "If it hasn't killed me yet, it's runnin out of time"    COG # 8062  AMA # 1084053  ROMA or Scarlet harlot acording to my wife
Plug for SISF
« Reply #1 on: July 09, 2010, 10:54:00 pm »
Ha! you think it's hot there - you oughta be here! I'm gonna have to break down and put a/c in the shop - some year! Steve
Offline John
  • COG#: 4157
  • Membership Level: Web Master
Plug for SISF
« Reply #2 on: July 10, 2010, 12:11:00 am »
Bill:    I have an idea that once you find the time to install them, you will be greatly surprised.  Steve did a set for me some time ago, then sent me an update, but the first time I fired it off, it ran pretty danged well, much better than stock.    tcars  John
tcars
John
COG 4157, AMA 390409, ROK Charter Member
SE Newsletter Editor
Offline oldsawfiler
  • COG#: 8062
Plug for SISF
« Reply #3 on: July 10, 2010, 01:21:00 am »
97* in the shade and dead calm.  Got 44 MPG on last tank.  That's up from 40MPG on the last several tanks.  I haven't installed the "new" carbs yet, but did drain the bowls and flush the old ones.  It had been running very rich and dripping smelling gassy when I shut it down.  I also installed an in line filter.  The weather is supposed to moderate over the weekend, so will probably switch them out Monday or Tues.  Looking forward to trying the "2 min. Mod"  "If it hasn't killed me yet, it's runnin out of time"    COG # 8062  AMA # 1084053  ROMA or Scarlet harlot acording to my wife
Plug for SISF
« Reply #4 on: July 10, 2010, 08:01:00 am »
yeah, but John, you have a few other things going on there that should also help the "much better than stock" feeling! Steve
Offline John
  • COG#: 4157
Plug for SISF
« Reply #5 on: July 10, 2010, 09:52:00 pm »
Steve:       Shhhhhh!  You're not supposed to let the secrets out.   :-)   Now the good news is, I have found someone to paint it, but it will be cooler weather before he can get to it.    I have to agree on the hot weather.  I ran the fans in the shop all night hoping to get up and out there early this morning.  Wrong, yard work took over again, then it was HOT again in very short time, and I was back inside.    tcars  John
tcars
John
Offline oldsawfiler
  • COG#: 8062
Plug for SISF
« Reply #6 on: July 12, 2010, 09:47:00 pm »
Got them in just did a test ride.  Feels great, but did not install the foam.  Not sure where it goes.  In the intake throat to the air box?  I think that I'll put her on Evilbay before I ever do a carb R&R again.  "If it hasn't killed me yet, it's runnin out of time"    COG # 8062  AMA # 1084053  ROMA or Scarlet harlot acording to my wife
Plug for SISF
« Reply #7 on: July 13, 2010, 05:01:00 pm »
Bill - there's no way it's gonna run correctly without the foam, so there's alot more greatness left - I did send you a couple papers with the carbs, didn't I? There's a description of foam installation at the bottom of the "upgrade" sheet - call me again if you need to. Steve
Offline oldsawfiler
  • COG#: 8062
Plug for SISF
« Reply #8 on: July 13, 2010, 06:08:00 pm »
Steve, It's running better than it ever has without the foam, but will put it in before I ride again.    Thanks  "If it hasn't killed me yet, it's runnin out of time"    COG # 8062  AMA # 1084053  ROMA or Scarlet harlot acording to my wife
Plug for SISF
« Reply #9 on: July 13, 2010, 07:04:00 pm »
Bill - be sure to read the part in the "tuning" section about cutting the foam. In fact if I were you, I would cut 1/2" off the WIDTH of one of the foam blocks and install it first, then ride the bike with some hard accells when warmed up, looking for any hesitation / flat spots. If you have none, you can even cut another 1/4" off the width, but no more. If you go to far, or have hesitation at 1/2" cut, install the full foam block, and don't try cutting more than 1/4" off the width, as you'll already know 1/2" was to much. You most likely will end up with 1/2" to 3/4" cut off being perfect. Keep in mind that as you cut you lean the mixture, which gives better fuel economy (to a point), but TO lean and theres no power. I know with no foam you're way to lean and if you took it out and romped on it, it'll fall on it's face. Let me know where you end up foam - wise. Thanks, steve
