Author Topic: Head Light Modulator  (Read 1049 times)
Offline MotoCommuter
  • Kurt Brown - SE AAD GA
  • COG#: 7115
« on: May 03, 2013, 01:03:10 pm »
Ok, obtained a head light modulator for my C10. There are no instructions with it but it seems to be a simple plug and go installation. There is a black wire that comes out of the black box, looks like it has a tiny light on it, anyone know what it's purpose is?
Kurt
Run With The Wolf: Sep 5-8
Spider Ride: Sep 12-15
Barber Vintage Festival: Oct 3 - 6
If it's not fun, why do it?
Offline Riverdawg
  • No more KAW, but still hanging around
  • COG#: 10535
Re: Head Light Modulator
« Reply #1 on: May 03, 2013, 01:06:57 pm »
Should be a photo detector to turn the modulator off at night. Usually recommended to mount downward so as to not "see"  yours or others vehicle lights. Don't know any states where it's legal to run a modulator at night.
  • COG#: 7115
« Reply #2 on: May 03, 2013, 01:17:24 pm »
Ok, makes sense. Any suggestions as to where to mount the light? Does it need to be kept inside the cowling or does it need to be exposed? Facing front? Facing back? Up? Down? Just want to get it right as I'll have to remove the cowling to install the modulator, and I just don't want to do it more than once. I just removed it last fall to replace my speedo cable.
Thanks!
Kurt
Offline Don
« Reply #3 on: May 03, 2013, 01:29:35 pm »
I didn't have to remove the cowling when I installed the one I got from Dragoon, although I did have the tank off.  If you can reach the plug on the headlight, you don't really need to remove anything.  Unplug the harness  from the headlight, plug it into the modulator harness and plug back in.  (takes all of a minute)
I ran the light sensor to the left mirror and stuck it out the top of the boot (my boot already had a slit to tighten the mirrors) and black RTVed it in place. (another minute).
  • COG#: 7115
« Reply #4 on: May 03, 2013, 01:44:43 pm »
Don,
Thanks, I hear what you are saying, but I have all kinds of other wires ti-wrapped to my fairing stay that I'll need to find a spot to mount the black box to. Plus, in the past I've found it difficult to swap out my head light bulb with out having to remove my cowling. I could probably do it but it would be less stressful for me to just remove the cowling.
I was thinking about having it come up through the dash vent so it is visible from the shield just below Buck's dash shelve. Should get enough light and be some what protected from the elements.
Kurt
Offline Victor Salisbury
  • COG#: 3673
« Reply #5 on: May 03, 2013, 03:53:34 pm »
I mounted my sensor, pointing down, on the small plastic piece under the headlight.  That was Sygnal Dynamics recomendation.   The one you supposedly remove to replace the headlight bulb.
Other "spots" up top, I actually had streetlights or other lights trigger the modulator at night.......
Vic Salisbury
COG #3673
'97 Connie "The Grinch"
Sarasota, FL
www.cog-online.org
Offline Alekkas
  • COG#: 10513
« Reply #6 on: May 03, 2013, 08:36:30 pm »
For my kisan, I have it routed and pointing up.  Did on my last bike too.   Did this so that it would modulate in as little daylight as possible.   Don't remember it ever getting wrongly triggered by a head light or street light or anything.
Seagiant needs to post more!
'08 C14 / PGR  / IBA
Some ride reports:
On two wheels:
Offline Bruiser
  • Bruiser
« Reply #7 on: May 06, 2013, 06:15:45 am »
The black wire w/ the gizmo on the end is a daylight sensor, which deactivates the modulator at night, cuz it is illegal after dark.  Just mount the sensor where daylight will activate it, like along the handlebar or someplace not too obvious.
« Last Edit: May 06, 2013, 06:17:38 am by Bruce »
Bruiser
2012 Kawasaki C14
93 Kawasaki C10
1982 Honda CX500 Turbo
1980 Kawasaki KZ1000ST
1978 Honda CB750F
1976 Kawasaki KZ400
1976 Honda 750K
1973 Honda CB500K
1973 Honda SL175
1972 Honda SL125
