Author Topic: I did it! Installed Murph's cruise control  (Read 2713 times)
Offline TnRider
  • COG#: 12484
« on: April 09, 2017, 03:46:25 pm »
I had to replace a frayed throttle cable so I thought I'd just go ahead and install Murph's cruise control as well this weekend.  This was all part of preparing for my 10 day camping trip next month.  I waited until today to try it out.  Wow! So nice to have.  I had forgotten how nice it was to have cruise control on a motorcycle.  This unit works great.  I did the screen door roller thing as well for clearance of the thermostat and reduce dragging on the cable/chain. It held my speed to within 1 to 2 miles per hour even when going up and down our steep Tennessee hills. Thanks Murph and all who did this before me!  :beerchug:
Offline turbo-max
  • COG#: 10445
Re: I did it! Installed Murph's cruise control
« Reply #1 on: April 09, 2017, 06:01:21 pm »
def a nice farkle to have!  :)
99 c-10 "the purple monster"
  • --2006 Concours--
« Reply #2 on: April 09, 2017, 07:11:19 pm »
It certainly is a 'luxury' that you soon consider a necessity.  For less fatigue when highway riding,
and occasionally shaking out the right hand, Cruise Control is awesome.
I never knew how much I needed it until I had it!
Enjoy!
Offline danodemotoman
  • COG#: 2877
« Reply #3 on: April 09, 2017, 10:56:41 pm »
 Years ago I thought that the poster was exaggerating about CC being his fav upgrade.
 THEN installed it on the '01 and it is now my fav and have had it on 3 C10's now.
Offline Happypilot
« Reply #4 on: April 10, 2017, 08:54:21 pm »
What is the screen door roller trick. Do you have a picture? I noticed this weekend that mine is cutting into the thermostat housing. Wondering how you mounted on in there.
Offline TnRider
  • COG#: 12484
« Reply #5 on: April 11, 2017, 01:08:50 am »
You'll find a write-up on it if you do a search of "cruise control".  I saw it in a post on someone having trouble with their cruise control.  Picked up a screen door roller from True Value Hardware.  Also bought a small screw, nut, and lock washer to fit the hole in the roller arm.  Drilled a hole in the cable holder and attached the roller.  :)
Offline Happypilot
« Reply #6 on: April 11, 2017, 01:12:41 am »
I had done many seraches on cruise control before i installed mine but missed that one.i will be buying one tomorrow. Thanks
  • --2006 Concours--
« Reply #7 on: April 11, 2017, 01:43:21 am »
A slightly larger image?
Whenever I have the tank off I schpritz some lithium grease on there to keep things "rolling".
Offline JimBob
  • Woman...WHOAAAA MAN!
« Reply #8 on: April 11, 2017, 03:42:06 am »
Well I'll be a SUMBEACH! What an idea! Where was this when I was installing mine?
And here I thought I done good by adding a plate that I bent to a curve, ground out the edge to mate to the frame, and have the chain/cable riding on it.
THIS is a mucho better approach, dangit!
Offline TnRider
  • COG#: 12484
« Reply #9 on: April 11, 2017, 11:54:37 am »
It was McFly's post where I got the info to do it.☺
  • --2006 Concours--
« Reply #10 on: April 11, 2017, 08:30:18 pm »
I gotta give credit to SteveJ.  He gave me the idea, ironically enough, at tech session
at SISF's.
Others have used a bent tube to guide the cable/chain.  SteveJ.'s was the easiest
to fabricate, with just a trip to Home Depot.   :great:
Offline Happypilot
« Reply #11 on: April 17, 2017, 07:11:28 pm »
I picked one up this weekend and installed it while adjusting my valves. just a great idea. then I got sidetracked and power coated my valve cover because it was missing some paint and bothering me.    Squirrel . I might miss summer if I don't keep from getting sidetracked and get it put together.
Offline Samonty
  • COG#: 12601
« Reply #12 on: May 31, 2017, 02:50:29 pm »
Does this system disengage by input from the brake light as well?
  • --2006 Concours--
« Reply #13 on: May 31, 2017, 09:23:38 pm »
Yes, It will disengage from the front or rear brake applied, or the clutch lever.  It can also be killed at the
control pad.
Offline Jim
  • Jim
« Reply #14 on: June 21, 2017, 04:48:11 pm »
Has anyone attempted to install the vacuum servo in the fairing or is it too heavy / not enough room?
Offline Stasch
  • COG#: 6830
« Reply #15 on: June 21, 2017, 07:12:36 pm »
Must have missed seeing that tweak 1st time 'round.
I've been using a ~3" section of garden hose to give the cable a smooth enclosure to run through but that roller is a very nice solution.
