Author Topic: Bar risers installed  (Read 380 times)
Offline Tour1
  • COG#: 9226
« on: March 16, 2020, 07:36:18 am »
I put on some not-new bar risers a while back.
This is just a quick view of them in response to a question.
If you are using this post as an installaion guide, be aware that the side view is of the right side riser.
The other pics are top views of the left side riser.
« Last Edit: March 16, 2020, 01:42:13 pm by Tour1, Reason: added left vs right picture note »
1987 Concours
2006 C50 Boulevard (sold in 2010)
2004 GZ250 (traded in 2008)
Offline crag antler
  • COG#: 8277
Re: Bar risers installed
« Reply #1 on: March 16, 2020, 08:54:13 am »
Looks like the Murphs risers I put on when I first got my C-10.
That and knee savers have made all the difference.
Doug aka crag antler
00 Kawasaki Concours 60,000+ miles. Bafflectomy,Bar risers, Murphs kneesavers, blockoff plates, allen head screw set,headlight upgrade. LED headlight, driving lights, free power mod, JC Whitney trunk, Go Pro mount,’06 header w/Jet-Hot ceramic coating, over flow tubes, 2 minute mod, carb spa and Performance Exhaust Sprocket by SISF,fairing extenders, CAT O-ring cruise control, Storz tubular bar adapter, Superbike handlebars
Offline Tour1
  • COG#: 9226
« Reply #2 on: March 16, 2020, 01:53:44 pm »
I think they're 1-1/4" risers, about the most you can do without swapping cables.  Having survived some butt-puckering moments with the OEM handlebar height I feel like too much height for comfort could be less safe for me to ride.
1987 Concours
Offline Jim Snyder
  • COG#: 7055
« Reply #3 on: March 16, 2020, 02:20:56 pm »
The best solution is converting to 7/8" bars. They improve low speed handling dramatically.
Offline Tour1
  • COG#: 9226
« Reply #4 on: March 18, 2020, 04:18:44 am »
As I recall my cruiser's bars were wider than the C10 bars.  I expect they would have had more leverage and more travel to get a given turn radius.
It would be nice to see a diagram with various bar heights and set backs (if that's the right word) versus the resulting body position.
I have a couple of books on ergonomics that couldn't hold my attention.  No chapters on motorcycles found so far.
So much work to be done...
1987 Concours
Offline Jim Snyder
  • COG#: 7055
« Reply #5 on: March 18, 2020, 11:52:43 am »
Tuning fork bars like those on a C-10 are notorious for causing wrist pain due to the narrow and down angle design. Standard 7/8" bars are flatter and wider. Less wrist pain and better handling, it's a win win scenario. I did the conversion on my C-10 shortly after getting it. When I moved to the FJR that was the first mod I did on it as well.
