Author Topic: Murphs Tip over bars  (Read 791 times)
Offline Giff57
  • COG#: 12709
« on: April 08, 2018, 06:20:23 pm »
Can anyone who's put these on tell me how you hold the nut on the back side of the top motor mount to keep it from spinning?
2006 Concours Blue
Re: Murphs Tip over bars
« Reply #1 on: April 08, 2018, 07:34:21 pm »
  Top right motor mount I was able to get a box end wrench on the nut and a socket wrench on the bolt head and torque the bolt. The top left motor mount bolt usually needs shims between the frame and the motor mount.
   THEN !!! I got a long socket of the correct size and a long extension to reach the nut on the left mount. (may have even had a swivel between the socket and the extension bar) Then I got my wife to hold the left side bolt while I torque the nut from the right side of the bike. A real pita to get at!!!
  I hope someone else has a better idea but that's my story!!!   :-[ :-[
Offline Giff57
  • COG#: 12709
« Reply #2 on: April 09, 2018, 01:01:09 pm »
I got it.  Since there is a Harbor Freight nearby, I went to browse for what might work.  I found a set of crowfoot wrenches that worked perfectly for removal and for starting the nut on the new bolt.  Best $8 I ever spent.
2006 Concours Blue
Offline Tour1
  • COG#: 9226
« Reply #3 on: April 10, 2018, 04:11:01 am »
That's what I did also.
I got mine used but un-used about 10 years old, though maybe the seller sold his bike 10 years ago & the bars are older.  They are Murphs style, not Canyon Cages, but w/o a known origin.  They don't have a small diagonal gusset that I recall seeing in a picture on somebody else's bars.  My set had 3/8" bolts in it IIRC.
A metric 10mm would be .3937" so, is this ok w/o worries, or should I get the exact fit?  I think I trimmed one for length, too.
Haven't done significant riding since they went on.   :truce:
« Last Edit: April 10, 2018, 12:56:30 pm by Tour1, Reason: spelling, knowns, & unknowns »
1987 Concours
