Author Topic: Is there still a market for millerized pegs?  (Read 4557 times)
millerized
  • Guest
« Reply #25 on: June 24, 2009, 04:27:00 pm »
Yeah...sorry about that I'm pretty sure it was mostly powder-coating, but I'm sure I tried all the bolt holes after I drilled them. Again, I apologize. I've drilled the latest ones a bit oversized, to make up for the powder bushing.  It's not really needing a tight fit since a little free play is ok, but tight is not right.    Noted, corrected, I thank you for your understanding.  http://millerized.com/pegs  COG 6425, CDA 111 a through g
Offline Colt45
  • COGnito Ergo Zoom
  • COG#: 7914
« Reply #26 on: July 11, 2009, 09:37:00 pm »
I have so of these!  I like 'em quite well for long trips.  I ordered the long version and then added some longer pegs similar to these:      They WILL scrape, but I've never been able to tell when it happened.      http://www.jcmotors.com/p-12208-kuryakyn-iso-pegs-female-mount-for-58-square-mounts.aspx
'00 748/853 "Rosetta"
