Author Topic: Issue removing front engine mount bolts to install highway pegs?  (Read 1843 times)
Offline bajakirch
  • CDA #0481 :-(
  • COG#: 10298
I just picked up a set of highway pegs from another member and was hoping to install them before a weekend trip I have planned in a couple of weeks.
If I understand correctly (haven't read through the install instructions) these replace the engine mount bolts. The thing is, I think I recall reading a post from someone that said when they removed one of the engine mounts, the engine shifted a bit in the frame and it was a huge PITA to reinstall the bolt.
I don't want what should be an evening installation project to turn into a weeks-long headache and prevent me from taking my upcoming trip.
Can anyone provide guidance on the issue?
If you can't be a shining example, at least you can be a horrible warning.
Offline CRocker
  • '02 C10 CDA # 416
Re: Issue removing front engine mount bolts to install highway pegs?
« Reply #1 on: May 09, 2013, 12:23:22 pm »
I don't recall having any such issue when I installed mine last year...you could put a scissors or hydraulic jack under the engine and snug it up before starting the process...but, I didn't...
HTH...
Offline GF-in-CA
« Reply #2 on: May 09, 2013, 05:32:19 pm »
I believe the highway pegs you show replace the lower bolts for the radiator mount, so you shouldn't have any issue with the motor mount bolts.
Gary F.
1998 ZGX1100
Central Valley California
« Reply #3 on: May 09, 2013, 07:17:57 pm »
   The front motor mounts are at the front of the motor just below the valve cover. Much too high for highway pegs.
Offline Hazy
  • COG#: 10534
« Reply #4 on: May 09, 2013, 07:22:35 pm »
I removed all 4 bolts (1 at a time) to install my front tip over bars. Didn't have any allignment issues. I popped out the old bolt, popped in the new one. That was it.
North Central Area
COG#:10534
Offline Eddie-FL
  • COG#: 7073
« Reply #5 on: May 09, 2013, 07:34:25 pm »
Gary F is correct. Those pegs mount on the lower radiator mount bolts.
Anderson, SC
1969 Triumph Bonneville
Offline CRocker
  • '02 C10 CDA # 416
« Reply #6 on: May 09, 2013, 08:19:19 pm »
That could explain why I didn't have an issue... :-[
Where's my sign...?
« Last Edit: May 09, 2013, 09:40:18 pm by CRocker »
Offline bajakirch
  • CDA #0481 :-(
  • COG#: 10298
« Reply #7 on: May 09, 2013, 08:43:58 pm »
Well that answers it then.
My motorcycle maintenance education continues...
Offline Outback Jon
  • COG#: 9506
« Reply #8 on: May 10, 2013, 12:57:26 pm »
Although from the size of those bolts, you'd think they were motor mounts.
