Author Topic: JMCB-2003 Noise  (Read 1782 times)
Offline smock
JMCB-2003 Noise
« on: June 10, 2008, 10:24:00 pm »
I installed my JBCB-2003 and for the first couple of rides everything seemed fine.  Now I have developed some noise/static that seems to be associated with the engine RPMs.  When the rpms change the noise/static seems to change as well.    Any ideas on how to get rid of this?    Thanks.
JMCB-2003 Noise
« Reply #1 on: June 11, 2008, 11:14:00 am »
Whats a JBCB-2003?  If it was fine then maybe your power and ground connection got loose.  Sometimes a power line coil will help.  Not sure where to get one anymore. I would try radio shack.  I know resistive plugs are what they use to say to add but I think the Connie plugs or wires have the resistor built in?  ----------------------------------  I will answer any question.  It is up to you to figure out if I should have.    <p align="left">My Photos<br
Offline Moto2wheelin
  • COG#: 5383
JMCB-2003 Noise
« Reply #2 on: June 11, 2008, 07:16:00 pm »
Where do you have the power wire hooked up?  I have always been told that it's best at the taillight wire.  I have always used this and never had any problems.
Offline smock
JMCB-2003 Noise
« Reply #3 on: June 12, 2008, 01:07:00 am »
Sorry for the typo, I meant JMCB not JBCB.
JMCB-2003 Noise
« Reply #4 on: June 12, 2008, 10:53:00 am »
http://www.twowheelsound.com/id3.html  There, not that wasn't so hard now was it.  Links are our friends.    I have never heard of this device before so I expect other have not either.  I will looking to it though since it looks interesting.  ----------------------------------  I will answer any question.  It is up to you to figure out if I should have.    <p align="left">My Photos<br
Offline MSRev
JMCB-2003 Noise
« Reply #5 on: June 17, 2008, 12:16:00 pm »
Do know what the j & m bracket number is that you are using to attach your cb to the handelbar?
