Author Topic: Murphs Headlight Harness  (Read 2365 times)
Offline Wess
  • COG#: 8010
« on: August 30, 2008, 10:26:00 pm »
For some reason my headlight harness has went out.  Does someone out there have the schematic that you could post or fax to me so I can trouble shoot it?    As always thanx for your assistance.  Respectfully Yours!  Wess Heavner  COG #8010 CDA #0239
Respectfully Yours!
Wess Heavner
Independence, MO
Offline oldsawfiler
  • COG#: 8062
« Reply #1 on: August 31, 2008, 12:42:00 am »
That's bad news.  I was just gettingt ready to order one along with hella lights and tipover bar mounts.  Hope its nothing to bad.    1990 Aint she a pretty Tomato (the bike ofcourse)  wedshots albums   http://community.webshots.com/user/sawfiler64/albums/most-recent
Offline Roger 123
  • COG#: 5903
« Reply #2 on: August 31, 2008, 07:50:00 am »
Are you saying that your Murph's harness has failed or that your stock one has failed and you're considering getting Murph's?  Roger ('07 Wee Strom)  COG 5903  Virginia Beach, VA
Roger '14 Tenere ES, COG 5903, VA Beach, VA
Offline Wess
  • COG#: 8010
« Reply #3 on: August 31, 2008, 09:32:00 pm »
My murphs is not working.  I did a valve job this weekend so I probably knocked a wire off or something as the only thing to actually fail is the relay, everything else is just a wire.      I cannot find my installation instructions and thought they would make troubleshooting easier.  Either way I will figure it out tomorrow morning.  Respectfully Yours!  Wess Heavner  COG #8010 CDA #0239
Respectfully Yours!
Wess Heavner
Independence, MO
Offline Roger 123
  • COG#: 5903
« Reply #4 on: September 01, 2008, 09:17:00 am »
Did you check to make sure that you have power to the stock headlight plug?  Remember that the stock plug is what triggers the relays.  Roger ('07 Wee Strom)  COG 5903  Virginia Beach, VA
Offline Wess
  • COG#: 8010
« Reply #5 on: September 01, 2008, 12:22:00 pm »
I had forgotten that it had its own inline fuse.  I would still like a copy of the directions and schematic if someone has them.  Respectfully Yours!  Wess Heavner  COG #8010 CDA #0239
Respectfully Yours!
Wess Heavner
Independence, MO
Offline Tinsailor
  • COG#: 7402
« Reply #6 on: November 06, 2008, 09:37:00 pm »
Wess you sound just like me, duh huh.
Offline CICogger
  • COG#: 4687
« Reply #7 on: December 02, 2008, 12:14:00 am »
Mine did, too and I replaced it,  The new version does allow for connection of lights to the low beam and another connection of lights to the high beam so I'm glad I replaced it.  However, I'm not 100% sure that the only problem with the old one was that one of the bulb elements burned out.  Replace the bulb before you do anything else.  It seemed that one of the wires to one of the relays had gone bad or lost a connection, but until I replaced the bulb, the new one did not work properly either.
Offline Ranger Jim
  • COG#: 6720
« Reply #8 on: December 02, 2008, 09:37:00 am »
Uh. Have you thought about asking Murph for another schematic? I suspect he'd provide one as he's a really good guy.
JIM CULP
