Author Topic: My dash lights are out. Any suggestions?  (Read 8260 times)
Offline Benjamin
  • What we have here, is' failure to commun'cate.
« on: October 11, 2015, 01:54:43 am »
Hey folks,
My dash lights are out; neutral, oil, turns and highbeam are good but I can't see any gauges at night because the white lights are out.
Murph used to sell a kit but no more.
Anyone else had this issue of late?  Doesn't have to be LED but I would like to see the gauges again.
Thanks in advance for any replies!
- Beej
'92 Concours ZG1000 - "Wilhelmina" w/ ZRX front end, C14 rear shock, 2MM, GeorgeRYoung's rearsets set up, stick coils, block off plates, Murph's heated grips, Corbin seat, Madstad windshield, ATV bars, semi-nekkid, Meanie rear
'09 Versys KLE650 "Ol' Blue" - SBS (Struck By Subaru) RIP
Offline CRocker
  • '02 C10 CDA # 416
Re: My dash lights are out. Any suggestions?
« Reply #1 on: October 11, 2015, 02:05:10 am »
Have you checked the fuses in the J-Box?
Offline Outback Jon
  • COG#: 9506
« Reply #2 on: October 11, 2015, 11:06:37 am »
They're 194 bulbs.  Available at any auto parts store.  Or you can get LED replacements.  (Look for 194 or T10)  There are 4 bulbs that light up the instruments.
You'll have to remove the instrument panel to replace them.  Remove windshield, the pieces with the faring pockets, and then the panel that surrounds the instruments.  The instrument panel takes 2x 10mm bolts, just below it, to remove.  Unscrew the speedometer cable, and you're set.  There's a metal bracket on the back that has to be removed to get a couple of the bulbs out, but it is easy to see how to do it once you have the panel in your hand.
If you get LEDs, make sure they light up before you reassemble everything.  LEDs are polarized, and (most) won't work unless they are installed in the correct orientation.
I did the entire instrument panel with LEDs.  In my opinion, it was well worth it since I was in there anyway.
A few things to note if you're going to replace everything with LEDs.
  • If you're replacing the indicator lights, use the same color LED as the indicator light.  GREEN for turn signals and neutral, RED for oil pressure, and BLUE for high beam.
  • With the usual 194 LED replacement, the HIGH BEAM indicator will be EXTREMELY BRIGHT at night.  You don't want that.  Get something like this one.
  • The clock uses a different size bulb.  It's a 74 (T5) size.
  • You can pick a nice color for your dash.  I went with blue and am quite happy with it.
  • Be careful, you might find you're addicted to LEDs.  I have replaced every bulb on my bike with LEDs.  (Except for the license plate light, which I have the parts for but haven't done yet.)  Yes, even my headlight is LED.
I don't know of anyone currently selling a kit, but here's what you need.
  • 4x 194 (T10) bulbs for the instruments.  Pick a color, or stick with white.
  • 1x 74 (T5) bulb for the clock.  Again, pick a color.
  • 3x 194 (T10) GREEN for turn signals and neutral.
  • 1X 194 (T10) RED for oil pressure.
  • 1X 194 (T10) BLUE for high beam. (See above)
  • Stayin' for the people....
« Reply #3 on: October 11, 2015, 11:21:35 am »
If ALL of your dash lights went out at once, the chance of it being bulbs all burning out is slim (but not impossible).
I'd start out checking the fuse as CRocker suggested.  Just replace it.  Sometimes it looks good and it isn't.
You may also have a loose connector or bad ground in the lighting circuit.  There's a lot of vibration on a motorcycle,
sometimes things shimmy loose.
Offline GeorgeRYoung
« Reply #4 on: October 11, 2015, 12:07:51 pm »
If it's a fuse, I think it would be the 'tail' one, and the brake lights wouldn't work either.
« Reply #5 on: October 11, 2015, 12:12:44 pm »
. . . I have replaced every bulb on my bike with LEDs.  (Except for the license plate light, which I have the parts for but haven't done yet.)  Yes, even my headlight is LED. . . .
Please enLIGHTen us, what did you use for an LED headlight?
I tried a number of cheapie eBay LED sets for the dash lights and they all died pretty quickly. Do yours last a while, and if so, what type did you get?
Offline Benjamin
« Reply #6 on: October 11, 2015, 03:31:28 pm »
^ Thank you!  This is incredibly detailed and contains all the info I was looking for and more! Wow! This place still surprises me with how helpful folks are.  Guess I should know by now.  :))
« Reply #7 on: October 11, 2015, 04:47:28 pm »
FYI; I tried the LED bulbs in the dash of my C-10.
        For the indicators, they worked fine.
For lighting the dash, didn't like them.
 The bluish color didn't highlight the speedo etc.
So, I went back to the 194's to light the dash.
I suggest you do the same,.
If you go with the LED's, Hopefully you can get a whiter LED and avoid the bluish colored bulbs...
Maybe someone can tell us the best (white) for the dash?
« Last Edit: October 11, 2015, 04:50:51 pm by connie_rider »
Offline WG
  • COG#: 4627
« Reply #8 on: October 11, 2015, 06:04:31 pm »
I installed the cool white versions of these LED bulbs in my dash
https://www.superbrightleds.com/moreinfo/rv-led-replacement-bulbs/194-led-bulb-5-led-miniature-wedge-retrofit-rvb/2485/
I find the gauges much easier to read with them vs. the stock 194 incandescent bulbs.
Wayne.
« Reply #9 on: October 11, 2015, 06:12:41 pm »
Thank you WG.
If a person wanted to replace all the bulbs, how many of each color?
4 white, 1 yellow, 1 green, 1 blue?
What about a LED for clock? (White)
Offline WG
  • COG#: 4627
« Reply #10 on: October 11, 2015, 06:35:20 pm »
Here's what I ordered:
3   WLED-G6 Green
1   WLED-R6 Red
1   WLED-B6 Blue
1   74-GHP Green
4   WLED-CW5 Cool White
Note that I didn't like how bright the neutral light was and switched back to the original.  I really like how bright the directional lights are.  I don't believe I've left them on since replacing the bulbs.  Note: this is for my 1999 C10.  I seem to recall that some of the lights (directionals?) are a different color in earlier models.
Wayne.
Offline Outback Jon
  • COG#: 9506
« Reply #11 on: October 11, 2015, 08:30:55 pm »
I've so far used two different LED headlights.  Both were plug-and-play, and I liked both of them.
The first one I used looked like this:
I like it.  When you switch to high beam, both the high and low LED stayed on, throwing a lot of light in front of the bike.  However, the high didn't seem quite adequate to me, but I like a LOT of light in front of my bike.  (As anyone who has ridden with me knows.  :o )   The high beam seemed to disperse the light too wide.  But it did work well.
The second one, I just put in the other day and don't have adequate night riding to really give an accurate review:
The high beam is MUCH more focused, and seems to be better to me.  The low is nice and wide, but seems like it might be a little higher than I'd like and might get into oncoming drivers' eyes.  (I might be able to just adjust my headlight down a bit and alleviate the issue)  I've only ridden once at night with it, so I'll have to get out more and ride and see if I get flashed a lot.  So far, though, I like it better than the first one.
As for the 194s, I picked up a bag of cheap ones off of Ebay.  They've been in all season and so far are fine.  I have some extra if one or more fail, but so far they all work.  I Intentionally got blue bulbs, and like how my dash looks.
« Reply #12 on: October 11, 2015, 10:07:09 pm »
Outback. Where did you get them, and what did they cost?
Offline Outback Jon
  • COG#: 9506
« Reply #13 on: October 12, 2015, 01:45:33 am »
Ebay, around $50/pair now.
Offline TinDog
  • COG#: 12674
« Reply #14 on: October 13, 2015, 12:54:02 pm »
3   WLED-G6 Green
1   WLED-R6 Red
1   WLED-B6 Blue
1   74-GHP Green
I ordered the same series of bulbs as WG did, with the exception of using the green bulbs in the instrument cluster too rather than white.  The green back lighting is brighter than stock, looks good, and still "works" well with the instrument color schemes (The blue looks cool in other peoples pictures, but many have commented how the blue doesn't really illuminate very well).  The light pattern illuminates the instruments effectively and evenly - no hot spots.  It's really nice to also be able to read the clock at a glance at night.
I agree the neutral light is very bright, but I'm okay with mine the way it is.  The problem I have is the high beam indicator.  I DO ride at night, and I DO use my high beams, and the blue high beam indicator is bright enough to be distracting and I'm sure hinders my night vision to some degree.  The bulbs WG and I both ordered are brighter than the original 194's. I'll probably be ordering something less intense for my winter commuting.
The same company sells other LED replacements for 194's; some are brighter than stock, some are less so.  Their product specification pages are really helpful;  note that specifications are often different for each color.  When ordering, also check if the bulb is over-sized or not.
People's results fro  LED's purchased on eBay or other sources seems to be hit and miss.  I've made a couple buys from Superbrightleds over the years and have not been disappointed.  Their product descriptions have been accurate enough to differentiate their products, and everything I've used has stood up to the elements so far.
« Last Edit: October 13, 2015, 02:41:17 pm by TinDog, Reason: Bad speeling »
Offline Outback Jon
  • COG#: 9506
« Reply #15 on: October 13, 2015, 07:23:17 pm »
Use ones like the ones I linked to above.  The LEDs on them go out to the side, instead of having one that shoots directly at you.  The high beam indicator on mine is now a little brighter than stock, but not much.
Or, be more frugal, and try putting a dot of black paint over the LED at the top of the array.
Offline buddybignuts
« Reply #16 on: December 15, 2015, 04:54:18 pm »
Thanks Outback, I think I am going to go with the second of the two headlight bulbs that you showed the pics of, (your new one) where can I buy it from and what do I ask for?
« Reply #17 on: December 15, 2015, 05:26:44 pm »
Fascinating, but doesn't help Beej get his dash lights working.
Offline JimBob
  • Woman...WHOAAAA MAN!
« Reply #18 on: December 15, 2015, 11:44:01 pm »
Basics:
1. Brake lights out? Then the lighting circuit is down - Check fuse, loose connections, bad ground, etc.
2. Just dash lights? Double-check fuse (yea, if brake's working it *should* be fine, but as Pops always said: K.I.S.S.)
3. Check wiring - corrosion in connectors can be sneaky. Check the dash light circuit, and double check the ground.
These kinds of problems are often pretty straightforward, in that you have little choice in the approach (though it can be tedious). Start from the power source and verify the path to the component (with a meter or a test light).
Offline Alas I have none
« Reply #19 on: December 16, 2015, 12:19:09 am »
That question was intended for a different thread, "Which LED Headlight should I use?" started by buddybignuts
Offline MichiGlenn
  • "Wherever you are, be all there" Jim Elliot
  • COG#: 10892
« Reply #20 on: December 16, 2015, 01:36:16 am »
If you're buying LED's, I got a code from superbrightleds.com for 15% off thru the end of Dec. it's SBL3K15   When I saw it I thought of dash LED's.
« Last Edit: December 16, 2015, 01:48:40 am by MichiGlenn, Reason: Grammar »
2001 C-10
1977 Honda CB750K Sold
1978 Honda CB750K Long Gone
1972 Honda CL175 Ancient History
Heald Super Tryke 8hp, Wards T555 Trike
Offline Swampcat
  • Editor of The Concourier
  • COG#: 12154
  • Membership Level: Concourier Managing Editor
« Reply #21 on: December 31, 2015, 12:37:38 pm »
3   WLED-G6 Green
1   WLED-R6 Red
1   WLED-B6 Blue
1   74-GHP Green
I did the conversion using these (though I used the WLED-B5 Blue for the background lights instead of the WLED-CW5 Cool White). I agree that the neutral light is too bright when using the WLED-G6; I can see it flash when shifting between first and second, especially at night. I've ordered a couple of other alternatives to see if they work out better for me. I'm also going to try the WLED-G5 Green and see if I like that color better for the dials.
I like the brightness of the WLED-G6 for the directionals. Between that and the beeper SISF had installed before I bought the bike, I have no excuse for going down the road looking like an idiot with my turn signal flashing.
The WLED-x5 lights are a little larger in diameter than the stock incandescent 194. I noticed that I had to angle them in a little to get them to slide into the back of the dash.
--Ed
2004 C10 ("Shoodaben")
1991 Vulcan 500 ("Lorath")
Send articles/pictures for The Concourier to editor@cog-online.org
« Reply #22 on: January 02, 2016, 11:34:34 am »
HEY!  Some of us leave that signal on for increased conspicuity (while looking like an idiot)!
I got the holiday crud New Year's Eve, so I just sneezed and coughed all over my Connie.
I've got a lot of resting up to do with the BMWNEF Coolest Rally coming up!!
Offline Swampcat
  • COG#: 12154
« Reply #23 on: January 06, 2016, 01:21:18 pm »
My latest(!) order from Superbrightleds.com arrived yesterday and I had a few minutes before nightfall to pull the dash and change the lights out.
I replaced the WLED-G6 on the neutral indicator with a WLED-G-90. It's a single LED with 90 degree beam angle (also available in a 120). This is the green version of the blue WLED-B-90 that I used in the high beam indicator. It looks like it will be visible enough in the daylight, yet not so bright that the flash on shifting first to second catches my eye.
I also changed out the WLED-B5 blue lights I used as the dash lights originally for the WLED-G5 (green). I think this is how I'm going to leave it. For some reason, the green seems to match the personality of the bike better in my mind.
My configuration is now:
2   WLED-G6 Green (directionals)
1   WLED-R6 Red (oil pressure)
1   WLED-B-90 Blue (high beam)
1   WLED-G-90 Green (neutral)
1   74-GHP Green (clock)
4   WLED-G5 Green (backlighting)
--Ed
« Reply #24 on: January 06, 2016, 04:19:27 pm »
Thanks Swampcat. Good info.
My old eyes didn't like the original (blueish hugh) LED's that were offered for the C-10, so I installed std incandescent's.
Need to go back in as some have burnt out.
Is the  {4   WLED-G5 Green (backlighting)} also offered as a white/White? (not bluish/white)
