Author Topic: New and exciting foot peg suggestions? Will GL1800 work??  (Read 6347 times)
Offline Benjamin
  • What we have here, is' failure to commun'cate.
« on: November 09, 2015, 03:49:48 am »
Hey folks,
Any suggestions for pegs out there?  I have tried the zx-9 and the Buell pegs.  I hear Goldwing pegs can fit with a little modification. Which year should I go for?
I'll take any suggestions; just haven't quite found the right one yet.  I was out with the Buell pegs today and my dang foot touched the ground on a turn; the angle on them isn't quite right.
Thanks in advance for any replies.
- Beej
« Last Edit: November 10, 2015, 06:39:35 pm by Beej »
'92 Concours ZG1000 - "Wilhelmina" w/ ZRX front end, C14 rear shock, 2MM, GeorgeRYoung's rearsets set up, stick coils, block off plates, Murph's heated grips, Corbin seat, Madstad windshield, ATV bars, semi-nekkid, Meanie rear
'09 Versys KLE650 "Ol' Blue" - SBS (Struck By Subaru) RIP
Offline Benjamin
Re: New and exciting foot peg suggestions?
« Reply #1 on: November 10, 2015, 06:38:56 pm »
Oh man bump.
I have scoured eBay and it looks like the GL1800 pegs are the right model but they are around $100 for a pair.
Can anyone confirm who has used various sets of pegs that Goldwing GL1800 or otherwise will work?
Offline cra-z1000
  • Keeping it upright..
  • COG#: 9790
Re: New and exciting foot peg suggestions? Will GL1800 work??
« Reply #2 on: November 10, 2015, 06:59:36 pm »
Im pretty sure the Murphs Kneesaver pegs are Goldwing pegs with a slight modification .
1987 C 10
80 Kawasaki KZ 1000 MK 2
74 Honda 750 four ss
73 Suzuki 550 triple
72 Honda 550 four
Offline Sparkie
« Reply #3 on: November 10, 2015, 07:43:10 pm »
Can you tell us what you want to accomplish?  I know I didn't like how close the pegs are to the shifter or brake lever so I wanted to move them back and down just a little.  I didn't want to give up much cornering clearance as I'm a peg scraper in stock form.  I ended up using some C14 pegs which are smaller in size when compared to the C10 pegs.  Then I made a lowering block to use with them and have been very happy so far.  Mark
2006 Kawasaki Concours (Sold)
2006 Ducati 620 Multistrada
2016 Yamaha FJR 1300A
Offline Benjamin
« Reply #4 on: November 11, 2015, 03:59:18 pm »
Good question!  :-[
I'm a tall guy at 6'3" and an aspiring peg scraper.  I dont need the pegs lower than stock but the zx9 pegs actually raise the height and thats no good.  I like the more sporty riding position afforded by having the pegs back a bit from the stock config but the Buell pegs are pointed downward so my foot hits the pavement before anything else in the corners.
What I'd really like is a flat peg thats a little lower down, like the stock peg, but not pushed forward.
The kneesavers are the GL1800 but I wonder if those pegs will hook right to the stock bracket or not.
Offline Sparkie
« Reply #5 on: November 11, 2015, 04:09:22 pm »
I believe the kneesavers do work with the stock brackets.  But as I understand they also lower the peg ht just a bit, thats the knee comfort part of it.  The GL 1800 pegs are also thinner than our C10 pegs.  Good Luck.
Offline delling3
  • 2nd Time Around
  • COG#: 11850
« Reply #6 on: November 11, 2015, 07:09:31 pm »
Murph's knee savers move the pegs down and back slightly (less than an inch further back).  The only time I have dragged one is when the bike was sliding on it's side down the highway.  The bike was totalled, but the pegs live on, mounted on my replacement bike.
Chris Delling
2006 Concours, risers, knee savers, throttlemeister, Murph's grips,  23" Clearview, KB fork brace, SISF's carbs, 2MM, and advanced exhaust cam gear, 7th gear, Spoofak.  Waiting in the wings:   McCruise Cruise Control.
Only dead fish go with the flow . . .
Offline ron203
  • COG#: 9847
« Reply #7 on: November 11, 2015, 10:19:50 pm »
Sparkie's right. I had the Kneesavers and my #13 boot tip would occasionally hit the road on hard turns and sometimes cornering. Very disconcerting. But I learned to slide my foot back on the peg and rest the ball of my foot on the peg when cornering. I've got a 35" inseam and big feet. Good combination to drag, BUT the extra leg room is good. I saved the C-10 OEM Rider pegs and swapped out the stubby pegs on my C-14 for them. The pegs are thinner, though.
I lost one of the new peg rubbers when I failed to check the set screws that hold them on when they were new (word to the wise) and replaced it with a 2008 GL1800 peg rubber. I took a guess at about how long I thought the Kneesavers had been on the market as starting about then.
2014 C-14
2008 Goldwing
Offline Outback Jon
  • COG#: 9506
« Reply #8 on: November 11, 2015, 11:31:17 pm »
The Kneesavers lower the pegs, but the GL1800 pegs are thinner.  It winds up putting them in nearly the same spot when it comes to dragging the pegs.  I recently had to replace the rubber on both of the GL1800 pegs from scraping them.
The Kneesavers use stock GL1800 pegs without any modification.  The Kneesavers itself is what adapts the stock bracket to the GL1800 peg.  There are no modifications necessary, everything just bolts up.  However, you can't just bolt GL1800 pegs to the C10.
Offline Benjamin
« Reply #9 on: November 17, 2015, 12:43:18 am »
This is what I was looking for (or dreading, I suppose). :-[  Thanks for the info. I guess I'll keep and eye out for kneesavers.
Thanks!
Offline Capo
  • Greasy Side Down
  • COG#: 10810
« Reply #10 on: November 17, 2015, 01:13:33 am »
In fitment speak the Concours pegs are male, the gl1800 female. And the kneesavers are,... well... nevermind...
James in Tampa. Currently being enjoyed are...04 C10,  86 C10 "Cooper" , 04 Honda vt750 "Christine" . The  only previously owned needing mention would be 74 gt750, I cant believe how many of us had a "water buffalo" !!!
Offline CRocker
  • '02 C10 CDA # 416
« Reply #11 on: November 17, 2015, 01:19:00 am »
Good save!   :rotflmao:
Offline Benjamin
« Reply #12 on: November 20, 2015, 03:57:40 pm »
How about putting the rear pegs on the front; I know folks have given this a whirl.  Any drawbacks?
Offline Stasch
  • COG#: 6830
« Reply #13 on: November 20, 2015, 10:06:45 pm »
I think they lower where your feet a bit, and they will move your feet back farther.  You will need a spacer to fill the gap of the smaller passenger peg loops where they attach to the rider footpeg brackets.
Hemicuda has done this, you could PM him for some more details.
Stan Visser - COG#: 6830
Offline Gitbox
« Reply #14 on: January 12, 2016, 12:43:48 pm »
I did this a couple years ago and kept it that way until I sold the bike. Worked great for me.
http://forum.cog-online.org/index.php?topic=48491.msg329240#msg329240
Remember that, Beej?  :)
2008 Yamaha FJR1300A
2004 Yamaha FJR1300 (sold)
2000 Concours ZG-1000 (sold)
Offline kz
« Reply #15 on: January 12, 2016, 12:53:14 pm »
I moved my rear pegs forward and find it to be more comfy...I'm 6'2".
Just used nuts, bolts and washers that I had in the shop. No longer spring loaded but they do still pivot if needed.
1987 ZG1000
Offline Benjamin
« Reply #16 on: January 15, 2016, 05:20:09 pm »
GITBOX!  Of course I remember!  Imagine my dismay when I couldn't find your diagram.  And now you've come back to C10 land and DELIVERED!  Thanks!  Hope you're well.  Hope even more you've got another C10; though I can't imagine you would want to do all those mods again.
Offline Gitbox
« Reply #17 on: January 20, 2016, 07:44:27 pm »
I pop in every now and then.  ;D
I sold the C10 and bought an FJR1300. The guy who got my bike got a super deal. He basically paid for my mods and I gave him the bike.
Love the Feej, by the way. Hey, it rhymes with your handle! :D
