Author Topic: Right Angle Valve Stems  (Read 1864 times)
Offline Boxer
  • COG#: 8908
« on: September 01, 2012, 05:11:24 pm »
I didn't find this topic in a search so I decided to ask:
Does anyone have a suggestion/experience with metal right angle valve stems.  I remember years ago on a BMW
forum someone wrote about one to avoid.  I picked up a digital pressure display gage so I don't have to put my
glasses on to read it but it doesn't work worth poop on a short stem.  I commute on the bike and check the air
a lot so convenience is a big concern for me.
Offline 6 Riders
  • "keep 'er under 90"
  • COG#: 10846
Re: Right Angle Valve Stems
« Reply #1 on: September 01, 2012, 05:23:16 pm »
I have a right angle in the rear, I assume thats what you are talking about? I HAD to put it on as I couldn't get air in the tire with the factory stem.
The rear wheel ONLY takes metal stems, so you'll need a valve stem specific to this type (MC) of application.
The front wheel takes a rubber stem, so any automotive valve stem "should" work, but it doesn't hurt to buy from a MC dealer to make sure that you are getting the right type. Note, not all dealers are good at getting you the right part.
If you interchange the two types of metal stems, you are going to be very unhappy and complain about how they don't work and why anyone shouldn't buy them.
Offline Outback Jon
  • COG#: 9506
« Reply #2 on: September 01, 2012, 11:29:32 pm »
I use the 85* (OK, it is almost a right angle) valve stems from kurveygirl.com .
http://kurveygirl.com/shop/product_info.php?cPath=27&products_id=72
They fit nicely on both the front and rear.  (Point them to the right so you can air up on the sidestand!)  And they seem to last quite a long time.  I am on my second set with 55k on the bike.  (Replaced the OEM stems when I wore out the OEM Dunlops)  I did the replacement because the gaskets looked like they had some small cracks where they were exposed to the weather.  When I took them off, I realized that I need not have worried, as the rest of the gasket looked like new.  About 30k on the first set, and I'm certain they would have done another 30k.  Oh well, for $10, I'm not complaining.
Offline C. Moore
  • COG#: 6662
« Reply #3 on: September 02, 2012, 08:18:02 am »
I've had the one's murph sells for about 7 years now. No issues. I think he still sells them.
'10 C14  Dallas, Texas
CDA #523
COG# 6662
Offline Boxer
  • COG#: 8908
« Reply #4 on: September 03, 2012, 02:58:25 pm »
Thank you for the responses.  I've got them on order.
Both of my C10's have been used bikes and came with shorty rubber stems.
I wasn't aware there was anything special from Kawasaki originally installed.
Offline mdr
« Reply #5 on: September 03, 2012, 05:02:50 pm »
Just for the 'archive', don't use one of the ones which just have a grommet holding them in.  Use the ones with the nuts as shown above.  The guy who mounted my rear tire put one of the grommet only ones on, and eventually the grommet failed, deflating the tire.
Mark in Austin, AE5SJ
'01 Concours, Vrooomm
http://www.randols.net/Connie/
http://www.mset-tx.org/
Offline turbojoe78_MA
  • COG#: 8645
« Reply #6 on: September 03, 2012, 10:38:15 pm »
I've been using these for over 12,000 miles and they seem real nice ... not cheep but they look good.   :great:
http://www.motorcycleanchor.com/tire_valves/index.htm
Offline SmokinRZ
  • COG#: 9430
« Reply #7 on: September 04, 2012, 01:55:09 pm »
Same thing happned to me.  Those things should be outlawed.
Also, the early 86-93 factory 90 degree does NOT fit the later model 94-06.  Go with Kurveygirl.
Offline ReserveBum
  • 04 Connie w/grey saddle COG # 9744
  • COG#: 9744
« Reply #8 on: September 08, 2012, 05:34:08 pm »
ditto on the cheap valve stem posts......I installed one when I changed my rear tire and it blew out at 65 on I-95 with about 375 miles on it. A true "pucker" moment. Got it off to the side w/o dropping it, set it on the kickstand then she fell over. At that point in time I didnt care...was happy that I did not get run over
