Author Topic: ROX bar risers  (Read 3009 times)
Offline John_Atkinson
  • COG#: 5921
John Atkinson
Windsor, ON
CANADA
COG #5921
Re: ROX bar risers
« Reply #1 on: July 29, 2014, 07:11:43 pm »
Someone posted a pic of them on a Connie a week or so ago. You'll need adapters to tubular bars: Concours Handle Bar Adapters and IIRC he had to use risers under them so the Rox risers would clear the top triple, then of course you'll need a set of regular 7/8" tubular bars. You might also need long brake and clutch lines if you choose bars that raise the handgrip position.
Offline Eddie-FL
  • COG#: 7073
Re: ROX bar risers
« Reply #2 on: July 30, 2014, 11:11:13 am »
Yes, they will. As WillyP said, you'll need tubular bars and an adapter. I'm using them with a KB bar adapter and EMGO Daytona Touring bars. I had to replace the brake hoses but I was going to a two line setup anyway. I was able to reroute everything else to get enough slack. I ran the throttle cables on the right side of the frame rather than the left. The enrichener cable was a little trickier, but it works OK.
Anderson, SC
1969 Triumph Bonneville
Offline AirMonger
  • COG#: 10838
Re: ROX bar risers
« Reply #3 on: July 30, 2014, 04:50:52 pm »
John, if you look at the tips and modification articals highlighted at the top of the accessories threads you will see my set up on page 3 of the killing the buzz artical. These are Storz (similar to the ones Murph sells) with the Rox anti-vibration risers in 7/8 configuration. These are certainly more exspensive than the standard risers but will do wonders for reducing the buzz associated with our bikes. I have two c10's, one with the Rox set up and one without. The difference is night and day. You will not regret spending the extra money for the isolator style risers. Steve in Sunny Florida was working on a one piece set up that accomplishes the same thing. His assesment is similar to mine on the effects of rubber mounted bars. I could not live without the set up on mine, or at least be able to extend the ride time that these allow me to enjoy now. Carpal is a bear.
"It usually takes 20 years before people begin to appreciate a good design." Kevin Cameron
Offline AirMonger
  • COG#: 10838
Re: ROX bar risers
« Reply #4 on: July 30, 2014, 05:09:37 pm »
Amazon has the Rox anti vibration riser listed by one seller at 113.95 with free shipping. That 41 and some change off of retail and less than what I paid for mine. Figures.
  • COG#: 5921
Re: ROX bar risers
« Reply #5 on: September 13, 2016, 07:01:15 pm »
Airmonger, I just came across this and tried to locate the page you referred to, but couldn't locate it. Can you redirect me?
John
John Atkinson
Windsor, ON
CANADA
COG #5921
Offline AirMonger
  • COG#: 10838
Re: ROX bar risers
« Reply #6 on: December 13, 2016, 05:28:17 pm »
John, sorry been off line for awhile. The Rox risers are available directly from Roxanne. I haven't paid a lot of attention to this matter since setting mine up. Still happy with them. My 87 Honda nighthawk S bars are the bomb combined with the antivibration risers. I will look around and see if I can find the link.
« Last Edit: December 14, 2016, 05:42:10 am by AirMonger »
Offline AirMonger
  • COG#: 10838
Re: ROX bar risers
« Reply #7 on: December 13, 2016, 05:36:22 pm »
Offline AirMonger
  • COG#: 10838
Re: ROX bar risers
« Reply #8 on: December 14, 2016, 05:49:30 am »
When the project was under development.
Offline AirMonger
  • COG#: 10838
Re: ROX bar risers
« Reply #9 on: December 14, 2016, 05:52:02 am »
As an added note: I removed approximately 1/2 inch from the center of the Nighthawk S bars for my personal preference.
Offline Bob
Re: ROX bar risers
« Reply #10 on: December 17, 2016, 12:29:08 pm »
I've been using Rox anti-vib risers on mine for a couple of years.  I started with the regular rox risers but still had too much vibration for my liking.  I picked up a pair of helibars and am going to mount them on the rox risers over the winter.
I have a newer set of Rox anti-vibs on another bike and it does seem the rubber gets hard with age.  It's not a problem yet but I may have to call them and see if the rubber inserts can be bought separately to refresh my older ones.
1986 ZG1000A1
IBA62582
Offline AirMonger
  • COG#: 10838
Re: ROX bar risers
« Reply #11 on: December 27, 2016, 10:54:33 am »
Keep us informed if the rubber is available separately. I have had my set up for three or so years as well. Want to put a inverted fork on the bike next and that is the beauty of the Storz set up. Should be able to transfer it all over to the new set up.
