Author Topic: Speedometer gear  (Read 1630 times)
Offline Mike
  • COG#: 12032
Speedometer gear
« on: September 06, 2015, 08:18:11 pm »
Needs some advice it appears that My speedometer gear thing that my cable screws into is squeaking.How would I greese it or do I have to replace the bearing?
Online tdbru
  • COG#: 10824
Re: Speedometer gear
« Reply #1 on: September 22, 2015, 01:46:13 am »
Mike,
can you be a bit more specific than "gear thing" please?  you can lube the speedometer cable with some heavy oil, like gear oil.  the cable has threaded caps at both ends, if I recall, so you'll need to be a wee bit more specific on which end of the cable you're talking about too please.
thanks,
Brian
Offline Pbfoot
  • COG#: 10807
« Reply #2 on: September 22, 2015, 12:41:48 pm »
The speedometer drive at the front wheel should be greased at tire change time.
Offline SmokinRZ
  • COG#: 9430
« Reply #3 on: October 01, 2015, 12:40:35 am »
There are no bearings.  Take it off and clean it in solvent of some sorts.  The ring gear comes out but the pinion gear is staked in place with a roll pin.  Clean it all up and grease it or it will fail.
