Author Topic: SPOOFAK Update  (Read 9417 times)
Offline Bergmen
SPOOFAK Update
« on: March 17, 2012, 08:31:10 pm »
I posted in this section in order for max audience. Mods, move this over to the "Accessories C10" if that is more appropriate.
I just talked to Gary Murphy on the phone this morning and we discussed the current state of affairs of the Spin On Oil Filter Adaptor Kit (AKA SPOOFAK). It appears as though market saturation is near and we are discussing just how many more of these kits we will order to keep on the shelves. If in fact the field has matured to the extent that demand wanes, I don't want to see Gary get stuck with expensive inventory on the shelf.
As a result, we have decided to stock about 50 more kits to see if there is continued interest. We will consider, after we see how this goes, whether it is worth keeping this kit in the listings. It is most economical (and fair) to buy the custom machined parts from the machine shop in quantities that make it worth the set-up and raw material acquisition. I insist on source certified material for the machining and this can be a bit of a logistical issue at times. The machine shop has been exceptionally good at meeting our needs (charging us for parts at 100 quantity prices when we only order 50 sets) but even 50 may be too much if demand lowers to the point of considering whether to sunset this product or not.
I'm just putting this out there for those who have been on the fence about getting a kit someday. There is likely to be a time when we will hang it up on the Bergmen Engineering Spin On Oil Filter Adaptor Kit and it would take a concerted demand for us to crank up the delivery chain again. I'm going to post this over on the ZRXOA Forum as well to give those hooligans another chance also.
It's all good.
Dan
--2014 Yamaha FJR1300A--
--ZGRX 1200 Concours (sold)--
--SPOOFAK Inventor--
Re: SPOOFAK Update
« Reply #1 on: March 17, 2012, 11:07:45 pm »
  Well I have mine!!  :) :)  Those sitting on the fence better get your Butts in gear.  :-[
Offline ManWorkingHere
  • Blue Streake
  • COG#: 9292
Re: SPOOFAK Update
« Reply #2 on: March 17, 2012, 11:34:05 pm »
I only wish I had got mine when I bought the cycle.  :-[
The kit was very easy to install.  Now it is paying for itself with every oil change.
after 2012 Rally
Offline Jim Snyder
  • COG#: 7055
Re: SPOOFAK Update
« Reply #3 on: March 18, 2012, 01:00:19 am »
I am still running my original test pilot adaptor and it has been flawless since day one.
Thanks Dan for a great product and for letting me be one of the guinea pigs.
Offline Bergmen
Re: SPOOFAK Update
« Reply #4 on: March 18, 2012, 03:18:55 am »
Without assistance by trustworthy experts like yourself, Jim, the kit would not have attained the performance objectives that it did. For those who do not know, Jim was selected to be one of the ten "test pilots" for the pre-production prototype adaptor kits and was asked to beat the thing up to see if there were any weaknesses. They took on some level of risk since they put their motorcycles (and engines) out there to run specific tests and provided invaluable inputs to refine the design.
There are about 1,000 kits out there in the field and the only returns have been with ZRX owners who have had difficulties fitting the kits with after market exhaust pipes that physically interfere. No performance related issues whatsoever. The Voyager crowd turned their collective noses up at the kit since the chief poo-bah was prejudiced against the kit from the outset (for silly reasons having more to do with stupid riding habits than anything else).
It's all good.
Dan
Offline Marty
  • COG#: 8165
Re: SPOOFAK Update
« Reply #5 on: March 18, 2012, 06:07:34 am »
I installed mine today. I went with a Purolator Pure One PL14612 (short one) and it touches the plastic just a bit.  I was wondering what others are using.  I'm contemplating cutting the belly fairing panel so I can run the taller filters and maybe change the oil without having to remove that fairing.  Anyone have any thoughts on doing this? Do a circular cut or whack out the whole cross piece? The cutout link on the Bergman site isn't working but it doesn't appear to be much to it.  I've been running about 1k mi/mo, mostly commuting, so anything to make it quicker and easier I like.
Offline danodemotoman
  • COG#: 2877
Re: SPOOFAK Update
« Reply #6 on: March 18, 2012, 07:08:29 am »
Not sure of the Bergman filter hole size but using a cut out for the stocker for years.
SNIP   I'm contemplating cutting the belly fairing panel so I can run the taller filters and maybe change the oil without having to remove that fairing.
Offline Jim Snyder
  • COG#: 7055
Re: SPOOFAK Update
« Reply #7 on: March 18, 2012, 10:44:56 am »
I have used the Fram TG-7317 filter (the one with the black rubber grip) since day one with zero issues.
It is the longer filter and I modified my belly pan to allow better access. I chose the longer filter for the additional capacity, and the fact that by it sticking down by the belly pan it provides an additional oil cooling affect as air passes over and around the filter and takes additional heat away. A dremel tool works great for modifying the pan, and the little sand paper drums work great for smoothing the edges.
Offline mellow yellow
  • COG#: 9301
Re: SPOOFAK Update
« Reply #8 on: March 18, 2012, 11:14:19 am »
this is one of the best upgrades to the bike that you can do. very easy to install and it makes changing the oil filter alot easier and you can stop in a walmart or automotive store to pick up a car style spin on filter instead of having to order a oem one. I don't understand the connection between ease of oil change and riding style of the voyager crowd.
05 connie
Re: SPOOFAK Update
« Reply #9 on: March 18, 2012, 12:39:46 pm »
I installed this on my '88 and I made a roughly half circle cut in the belly pan. I used a hand saw that uses blades for a jig saw.
Offline Bergmen
Re: SPOOFAK Update
« Reply #10 on: March 18, 2012, 02:43:51 pm »
I shouldn't have been too harsh with those guys. The oil filter apparatus hangs low and to the rear and looks vulnerable. But I explained that there would likely be no problem as long as they didn't ride off a curb or something (I explain this in detail on my website). I suggested that this is risky to the undercarriage of a motorcycle anyway, SPOOFAK kit or not. So the guy decides to buy a kit and then procedes to ride off a curb and bash the filter. We took it back for a full refund and decided to aim this at the ZZR, ZRX, Concours, etc. crowd.
The only issues with the Rexxers so far has been interferences with some aftermarket exhaust systems (Akrapovic comes to mind) that prevent installation and service.
BTW, thanks everyone for the kind words on the kit, it will be seven years old in May of this year:
Here is a view of the modification drawing:
I can send the pdf to anyone who wants one (I'm not sure why the link is busted on my site) by e-mailing me at bergmen-at-pacific-dot-net (@.).
An alternative modification is to remove the crossbar completely. In my case, I cut the belly pan short:
Here is an assembled comparo:
Then, after the engine swap I left the tupperware off altogether. Eezee peezee that way.
Dan
Offline Jim Snyder
  • COG#: 7055
Re: SPOOFAK Update
« Reply #11 on: March 18, 2012, 04:46:18 pm »
Boy Dan I would love to see what that red devil would do with my exhaust on there?
Offline Outback Jon
  • COG#: 9506
Re: SPOOFAK Update
« Reply #12 on: March 18, 2012, 08:25:59 pm »
I just cut out the entire crosspiece on my belly pan.  (Actually, I had already done that so I could change the stock filter without removing the belly pan)  Just two straight cuts with a jigsaw was all it took.  Now I can drain the oil and replace the filter with no prep other than putting the bike on the centerstand.
Offline Jorge
  • COG#: 9297
Re: SPOOFAK Update
« Reply #13 on: March 19, 2012, 12:21:24 am »
Hey Dan,
I'm one of those in the fence, and after having changed the oil and filter yesterday, I've almost fallen off (you guess which way).
That was one of my concerns... I don't PLAN to drive off a curb, but you don't always do what you plan.
Have you heard of anyone punching a hole in the filter because it hangs low?
It's also possible that if you were to hit, would you punch a hole, or deform the filter, reducing flow, but not losing your oil? I know if I were to hit, I would stop immediately and check for damage.
I've used K&N filters several times on our cars and trucks, and they are much thicker than the typical filter, but have that square drive which is great for a car/truck, but it makes it hang lower... thoughts?
Thanks, and congrats on an elegant design.
Jorge
Re: SPOOFAK Update
« Reply #14 on: March 19, 2012, 03:18:48 am »
  I use the short filters on Bergman's list of filters he supplies with the kit. It is barely longer the the oem setup.
Offline DannyL
Re: SPOOFAK Update
« Reply #15 on: March 19, 2012, 03:48:54 am »
I'd be interested once they are in stock.  :beerchug:
Looks like I still have a few pieces of puzzle to fill in!
2005 Concours
Re: SPOOFAK Update
« Reply #16 on: March 19, 2012, 12:23:36 pm »
True. If you use the short filters they will barely extend from the from the oil pan. No more, or not much more, than the bolt head for the stock setup. And if you hit that stock bolt on something, you'll do more damage to the motor than if you hit the spin on filter. The long filters extend just a little further, and I could see a legitimate concern there, though I think it's very unlikely. The long filters I used are roughly flush with the bottom of the belly pan and if you had hit something and scraped the bottom of the pan you certainly could crush the bottom of the filter. I switched to the shorter filter mainly because of that.
I also had a pick of the '88 with a long filter from the side, going into my storage place, the floor is a good 8" or so higher than the pavement, no ramp. And there is plenty of clearance.
I don't have a SPOOFAK on the '01 yet, it is on my list of wants. Business needs to pick up first though!  :(
« Last Edit: March 19, 2012, 12:29:29 pm by WillyP »
Offline Rev Ryder
    • Presbychuck
  • COG#: 7235
Re: SPOOFAK Update
« Reply #17 on: March 19, 2012, 12:54:53 pm »
Hey Dan,
Having done this, I am compelled to write a short response.
When moving a couple three years ago, I had to load the turbo into the back of a large, 24ft. Uhaul truck.  The ramp was fairly steep and I was rinning the long filters on the SPOOFAK.  Long filter story short, I hit the ramp with some velocity to make sure I made it all the way up and at the peak where ramp meets truck, the filter struck the latch holes in the bed of the truck floor ripping the filter in half.  Yes, it can happen, but it sure isn't likely.  However, the real meaning of this post is to praise the integrity of the SPOOFAK... the filter was smashed, torn, and pumping oil like an Exxon freighter (into the bed of the truck with all my furniture and stuff), but the SPOOFAK was totally undamaged.  I am not kidding, I hit hard and used the edge of the SPOOFAK like one side of a scissors to shear the filter off and still only took a couple of small marks to the aluminum and no change to the seal or performance of the adapter itself.  A big bag of oil dri, a dozen rolls of blue towels, and a new filter and oil and things were all back to normal.
Now this WAS with long filters... a lowered bike (due to the ZX14 forks), and a steep ramp angle into a truck facing downhill.  Yes, you could do something similar going down a curb, but the good news is that the unit is likely to be unhurt and you are BOUND to stop if you take a knock that hard.  Just my .02 and my thanks to Dan and Murph for such a fine product.  If everything you ever bought were half as good, you'd only buy them once.
Fortis non Ferox
 Shafties Can't Wheelie
Offline Bergmen
Re: SPOOFAK Update
« Reply #18 on: March 20, 2012, 03:33:58 pm »
Hey Dan,
Jorge
Here is a write-up I did on filter vulnerability:
If I choose a long filter, is it safe from damage while riding?
To be honest, the filter does present a certain vulnerability to impact damage. The long filter more so than the short one. Careful motorcyclists generally do not allow the underside of their engine or motorcycle to be exposed to any potential (or real) impact if at all possible. Even under the best of circumstances, though, the potential for unavoidable situations is always there (going over a curb, aggressive speed bumps, an unseen large pothole hiding in a shadow, etc.). One fallback preparation for those that could (and sometimes do) incur impacts that might puncture a spin-on filter is to carry a spare filter and the cup wrench provided with the kit to replace a damaged filter. This sort of impact would almost certainly occur at very slow speeds and it would be safe to assume that the rider would immediately dismount to check for damage after any such impact.
One other thing to keep in mind is that loose sharp objects that pose a puncture hazard to the filter stand a good chance of puncturing the rear tire right after that. So if the rider is always on the lookout for anything that may harm the tires, the oil filter will benefit from that level of scrutiny.
Here is a picture of the long filter protruding:
Short filter installation for comparison:
Dan
Offline Outback Jon
  • COG#: 9506
Re: SPOOFAK Update
« Reply #19 on: March 21, 2012, 12:15:36 pm »
Wow.  So not only do you have oil pumping out onto the ground in front of your tire, you get to have a flat as well.  Sounds like fun!   :-\   :rotflmao:
That said, I just did my first change after the initial install of the SPOOFAK, and I am thrilled to have it installed.  Though a word of advice, if you're going to do the change on a nice day, make sure you have the filter in hand before you drain the bike.  I was certain I knew where my new filter was, until I went to look for it.  Had to take the truck to get a new filter.   :-[
Offline Bergmen
Re: SPOOFAK Update
« Reply #20 on: March 21, 2012, 02:24:38 pm »
I've gotten to the point that I buy filters in bulk (10 at a time) just so I won't be in the same predicament as you were. I do the same for oil, keep a couple of cases handy.
BTW, just to put the potential for filter damage in perspective, I have not heard of a punctured filter leaking oil yet (IIRC, I am getting older so I may have forgotten). I have found a few gnarly dents on my filters that were more than just dinks (technical term) but not close to puncturing. I do a lot of riding on smooth gravel roads, some with sharp cornered gravel that has given my filters a pretty good test of rock impacts. Just to be safe, though, I put a guard in front of my filter made out of extruded aluminum angle stock:
Dan
Re: SPOOFAK Update
« Reply #21 on: March 21, 2012, 03:00:15 pm »
Now all Jon needs are puncture proof tires.
Offline DannyL
Re: SPOOFAK Update
« Reply #22 on: March 22, 2012, 02:56:45 am »
Are they ready yet?  ;)
2005 Concours
Offline Bergmen
Re: SPOOFAK Update
« Reply #23 on: March 22, 2012, 03:17:44 am »
Being machined as I write this. Can't give you a time when all is together, don't have the commitments from the shop.
Dan
Offline Tensator
  • COG#: 8044
Re: SPOOFAK Update
« Reply #24 on: March 25, 2012, 01:23:48 am »
Putting a farkle list together now, count me in!
Arriving somewhere but not here.
