Author Topic: Stebel Nautilus install pics .  (Read 2334 times)
Offline cra-z1000
  • Keeping it upright..
  • COG#: 9790
« on: August 05, 2012, 07:32:56 pm »
Installed my stebel nautilus . Went well and used Murphs harness . After blowing the horn 3 or 4 times the inline 10 amp fuse will blow . Searching online it seems most people up that fuse to 15 amp to resolve this issue . Sound right to you guys ? I also wondered if the horn is grounded through the mount. I used a plastic spacer on the install which would interuppt the ground if so and can replace in if nessacary. Thanks in advance !
« Last Edit: August 16, 2012, 07:13:05 am by cra-z1000 »
1987 C 10
80 Kawasaki KZ 1000 MK 2
74 Honda 750 four ss
73 Suzuki 550 triple
72 Honda 550 four
  • COG#: 13095
Re: stebel install question
« Reply #1 on: August 05, 2012, 07:35:10 pm »
The  air pump has its own ground wire and that is all that is required. My fuse happens to be a 20amp but it runs the stebel  horn and driving lights. Your good to go.
Offline cra-z1000
  • COG#: 9790
« Reply #2 on: August 06, 2012, 01:35:04 pm »
Thanks man . Wonder why the harness comes with a 10 amp fuse ? Sounds like a lot of people had this issue .
1987 C 10
72 Honda 550 four
Offline Slybones
  • COG#: 6953
« Reply #3 on: August 06, 2012, 04:02:29 pm »
I though a Stebil Nautilus sucked 18A when it was played. The Stebil HF80 models are 4.5A each for 9A total. But the Nautilus was twice that.
2003 Concours, 121K
2005 GL1800ABS, 52K
COG #6953, IBA 28004
Offline cra-z1000
  • COG#: 9790
« Reply #4 on: August 07, 2012, 01:16:34 pm »
One hell of a horn....highly recomend this !
1987 C 10
72 Honda 550 four
Offline John_Atkinson
  • COG#: 5921
« Reply #5 on: August 07, 2012, 05:25:56 pm »
Any pics of the install?
I'm getting ready to put mine in and am wondering about location...
John Atkinson
Windsor, ON
CANADA
COG #5921
Offline cra-z1000
  • COG#: 9790
« Reply #6 on: August 07, 2012, 07:19:25 pm »
Ill try to post some up . I always have that sizing issue with photos. I removed my fairing pocket on the left side and used the mounting hole for the bottom of the pocket to mount the horn . It only fits one way but it was the right way as far as having the opening down . The harness worked great where it is....plug and play . Just followed Murphs instructions to hook up .I did have to take loose the gauge cluster to disconnect the
stockers and gettt at the connections
1987 C 10
72 Honda 550 four
Offline cra-z1000
  • COG#: 9790
« Reply #7 on: August 07, 2012, 07:25:07 pm »
I did have to sacrifice the pocket on the left side but my 87 has the vinyl button cover over that pocket and I didn't use it much anyway . The cover buttoned right back on so its invisible .
1987 C 10
72 Honda 550 four
  • COG#: 5921
« Reply #8 on: August 07, 2012, 07:40:16 pm »
thanks cra-z1000 ...I'd be very interested to see what you've done
John Atkinson
Windsor, ON
CANADA
COG #5921
Offline cra-z1000
  • COG#: 9790
« Reply #9 on: August 15, 2012, 09:29:26 pm »
Finally getting some pics up of my install. I'm pretty happy with it .As I said I did lose the left pocket but with the cover back on I can still hang my shades there so its all good .
1987 C 10
72 Honda 550 four
Offline cra-z1000
  • COG#: 9790
« Reply #10 on: August 15, 2012, 09:35:51 pm »
Couple more .
1987 C 10
72 Honda 550 four
