Author Topic: Top Luggage Lock  (Read 535 times)
Offline tim_cannon
Top Luggage Lock
« on: March 08, 2012, 02:21:12 am »
Not the latch but the little doohiky that it latches on to.  The inner threads on the hole for the mounting screw have apparently sheared off.  It's a really tiny hole.  I have super glued the screw in the hole for the time being.
If I buy the OEM lock assembly ($58.00), does it come with this part?
I'm thinking of trying a slightly larger self tapping screw as a replacement.  Any thoughts?
Tim
'05 (el Chaparral)
Offline ChipDoc
  • COG#: 9934
Re: Top Luggage Lock
« Reply #1 on: March 08, 2012, 09:25:22 am »
You might try a bolt with a washer and a nut that would fit through the existing hole.  I actually drilled mine out to fit a bolt I happened to have on hand and it works fine.
