Author Topic: Trunk Recomendation  (Read 2301 times)
Offline Samonty
  • COG#: 12601
Trunk Recomendation
« on: May 09, 2017, 12:24:26 pm »
Did Kawasaki ever have a factory trunk for the c10? I'm looking for one that has a backrest or that can have a pad installed for passengers, can anyone recommend one that's at a reasonable price point?
Online connie_rider
Re: Trunk Recomendation
« Reply #1 on: May 09, 2017, 01:58:05 pm »
Kawasaki didn't make a factory trunk.
Part of your question should include, how big of trunk do you want?
There are hundreds of possible trunks, in many different sizes..
I suspect that most of us, have the Givi Trunks...
NOTE: One member just posted a basic small trunk {from Ebay} that cost about $40 and it has a pad..
Discussion is here; http://forum.cog-online.org/accessories-c10/cheapo-ebay-top-case/msg592279/#msg592279
« Last Edit: May 09, 2017, 03:43:34 pm by connie_rider »
Offline cra-z1000
  • Keeping it upright..
  • COG#: 9790
« Reply #2 on: May 09, 2017, 02:53:14 pm »
I have an Emgo mounted on the factory rack with the backrest . Matches the side bags pretty gòod . Wizard may have a rack for you . The trunk was about 40 bucks .
1987 C 10
80 Kawasaki KZ 1000 MK 2
74 Honda 750 four ss
73 Suzuki 550 triple
72 Honda 550 four
Online ron203
  • COG#: 9847
« Reply #3 on: May 09, 2017, 08:58:23 pm »
I have the Givi because when I was shopping it was the only one (that I could find but there may be others) that offered a factory backrest as an option. My hunch is that the Givi might be stronger for some reason because of thickness, design or the like. Pricey but seems to be substantial enough for someone to lean on it.  Like I said, there may be others.
2014 C-14
2008 Goldwing
Offline Samonty
  • COG#: 12601
« Reply #4 on: May 10, 2017, 03:07:35 pm »
Thanks for the feedback, I sent a PM to Wizard to see if he has a rack. I'm not as much concerned about size 'cause most I'll just be storing a rain suit and my daily lunch. Appearance is more important, I'm sure though once I star using it it will be too small.
Offline BrianD
  • COG#: 11685
« Reply #5 on: May 10, 2017, 04:21:53 pm »
You might want to check these out - there have been some good reviews on here about them.  And they are currently on sale!
http://www.bestemusa.com/T-Box-2012-42-Ltr_c_1302.html
Brian Dutton
Coventry, CT
'02 Concours
Offline oldsmoboat
  • 2004 C10
« Reply #6 on: May 20, 2017, 02:09:32 pm »
I have the Shad 46.  It's way over priced.  I forget what rack I have it on.  If Phil made one for the C10, it's probably that one.
EDIT: Or Murph's mount kit, maybe.
